ESR meter upgrades
This is a sticky topic.
    • 30950
    Re: ESR meter upgrades
    i was unable to watch that all the way through, it was too painfull.
    that's why i hate utube.
    so the FSC error is because the chinese programmer auto-detects the correct speed and ignores the parameter - so ignore it.
    he pulled the chip and breadboarded it - why? just connect the header to the bottom of the programmer socket and the crystal is already there.
    his breadboard was unreliable anyway - the crystal should have a pair of 18-22pf caps to ground - he didnt fit any!
    and all you need to do for avrdude is copy & paste this:
    avrdude -c USBasp -P usb -p m328p -U flash:w:TransistorTester.hex \-U eeprom:w:TransistorTester.eep \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
    job done
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #262
      well when all my bits come i will get you too help me copy the working chip contents onto the faulty chip that way i have two meters hopefully working then and can start upgrading one with your help i you dont mind that is.But will need help in the programming side of things if you dont mind as its all new too me so a guide mayhelp a few members as if everyones ic is blank on these kits there going to need too know how to programme it too.
        • 30950
        do you have a Linux setup?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #264
          only xp-vista_win 7 _win 10 at the minute but no linux never used it.
            • 30950
            hmm. have to get the libusb driver first then.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #266
              stj a question rather than add a header to the pcb for upgrading the files to the tester could i use one of these? as ive been offered one for free if i go and collect it and it may make the upgrades easier for me as ive never done programing before
              http://www.ebay.co.uk/itm/2622305495...%3AMEBIDX%3AIT
                • 30950
                i have never used one, so your on your own with the software, but i would take it for 3
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #268
                  i was wondering if it could take your modified files you upload ie the crystal upgrade etc. it will probably copy my good chip contents onto the blank kit one ok though i guess and make a working tester.
                    • 30950
                    well tbh the 10pin header is a lot simpler than constantly removing the display and pulling the chip.
                    it makes no difference to *how* it's programmed - it just saves stripping the unit to get at the programming signals.
                    you should fit the header and grab the 866 for other things.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #270
                      can you do a guide on programing it your way? as a lot of people may find it usefull and only have a windows pc etc ive ordered all the parts anyway just waiting for them too come.
                        • 30950
                        you install the libusb driver from here:
                        http://www.fischl.de/usbasp/
                        and the latest AVRdude from here:
                        https://cdn.badcaps-static.com/pdfs/...0e8896b305.pdf
                        http://download.savannah.gnu.org/rel....3-mingw32.zip
                        to program the chip, simply use
                        there is a slightly different command to read one.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #272
                          Hi thanks for the info stj another question for now have you got a diagram to where to solder the wires for the 10 pin header wires too as hopefully parts will have been delivered today.
                            • 30950
                            you know i do
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #274
                              Originally posted by stj
                              you know i do
                              Thanks for that stj whilst im waiting for the parts for may 2016 version tester i have one of the older type testers mine is the one without the crystal i see in the other picture it has a crystal added can i add one to this tester as im also thinking about changing the main ic too the larger capacity as its only 99p so worth the upgrade and i could update the firmware etc then can you offer any advice? this is only a spare tester but might as well upgrade it im not bothered about a rotary enoder etc i just want acurate test results.
                                • 30950
                                adding a crystal is no problem, dont forget a crystal needs a pair of 22pF ceramic caps between the legs and ground.
                                (looks like the fact that RS sells the crystals in 5's isnt so bad!)
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #276
                                  ive got 5 crystals so alls good the caps ive just ordered is there a guide which pins etc to connect the crystal and caps to my tester in picture one thanks again
                                    • 30950
                                    these probably help
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #278
                                      these probably help
                                      Thanks it sort of helps (im still la newbi remember with electronics ) so crystal legs to pb6 and pb7 with a 22p capacior on each leg to ground?
                                        • 30950
                                        no, dont know how you came up with that.
                                        crystal to xtal1,xtal2 (pb6, pb7)
                                        keep the wires short.
                                        personally i would use a pair of smd caps and just solder them between the pins on the actual crystal can.
                                        pd1,pd3 are the rotary encoder mod!
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #280
                                          sorry i edited my post as you was probably writing yours the last thing as i will be installing the larger ic too take the crystal and updated firmware how do i find the files i need to write to the chip i will need all the firmware files i guess not just the updates (i might programme the chip using that free programmer i need to collect this week ) so it will also save me adding a header on the board as i didnt order spares of them.
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
