Thread Tools |
#841 |
City & State: Europe
![]() maybe i will manage to do some releases by the weekend!!
the build-rig is back together, i just need to back up the drives before i do anything else with it. |
#842 | ||
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
![]() Just saw this on the German forum that I had missed:
"The one who says it cannot be done should never interrupt the one who is doing it." |
#843 |
![]() i knew about that - it's documented in the code.
it does not alter the fact that 90% of the time there will be something else in parallel with the cap that screws with the reading. ![]() |
#844 |
City & State: Grovetown GA
![]() I thought about using 2 cells but there's no off the shelf USB charge module available. The module I'm using seems like it's OK I used it on my DSO150 scope build. Will I have to recompile the firmware with a lower low battery threshold?
#845 |
![]() yes, or it will switch off as soon as it tells you the voltage.
i wouldnt know about usb charge boards - i dont trust lithiums so i only charge them in the standalone charger. |
#846 |
![]() update
only GM328 for now - the build-box is in bits and RSYNC is doing it's thing. ![]() btw, as usual there is some functions not activated by default - well they are now. i had to drop down to 8x8 font to get everything to fit for now - until i can rip the contrast menu out again! ![]() |
#847 |
City & State: ----
My Country: Sweden
![]() As I said here I think the 8x8 font is better anyway so leave it in
![]() https://www.badcaps.net/forum/showpo...&postcount=767 |
#848 |
![]() the build box is now running - as a room heater!!!
so if anybody wants any custom builds - just ask. tell me the hardware and anything "custom" needed, and i'll compile it. |
#849 |
City & State: Sao Paulo
My Country: Brazil
![]() Please stj, when possible, post a recent version for "AY-AT". Thanks.
#850 |
![]() not tested.
#851 |
![]() if your room is still cold, please warm it up and compile one for me! AY-AT board, ST7735 display, 16 mhz and I need the low voltage cutoff set to a more li-po friendly value I guess 3.2 volts?
#852 |
![]() o.k.
#853 |
Solder Sloth
City & State: CO
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
![]() Speaking of these AVRtesters, has the 16x2 LCD become deprecated or will they still work just fine with all the new features? (of course, no pretty artwork unlike on the graphic displays...)
#854 | |
![]() Quote:
you really need an atmega328p if you have an atmega8 / atmega168 then you dont have enough flash memory. on the bright side - they all have the same pinout - so you can upgrade the chip. make sure you get it from china though, or it will cost almost as much as a new tester. |
#855 | |
![]() Quote:
anyway - i made several - so no problem. |
#856 |
City & State: Nuneaton Warwickshire
My Country: uk
#857 |
![]() afaik it's always present if the menu is enabled.
#858 |
My Country: uk
#859 |
Solder Sloth
City & State: CO
![]() I would imagine the 16x2 LCD's would require less memory because they don't have any graphics to store! (?) Then again you can program bitmaps into them...
I also hear that the mega8 and mega168 lack features like adjustable vref and thus can't do as much as the mega328 anyway, so that stuff can be compiled out, saving some flash? |
#860 |
![]() so what chip do you have?
Thread Tools | |
