Thread Tools |
#881 |
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
![]() If you are building on CentOS7 or RHEL7 I made a small writeup here.
If not the version of GCC should still be relevant no matter what build OS you have. https://www.badcaps.net/forum/showpo...&postcount=773
"The one who says it cannot be done should never interrupt the one who is doing it." Last edited by Per Hansson; 12-03-2017 at 01:25 PM.. |
#882 |
City & State: cullompton devon
My Country: england
![]() I have just received a couple of 16mhz crystals and fitted one to my T4 tester
with the old program which is v1.12 all the capactors read double there value where as resistors and transistors seem to read within tolerence, I have tried several 16mhz firmware upgrades with no luck just a blank screen, any suggestions ? if all else fails I can always revert to the 8mhz crystal. the original firmware was V2.68 which I lost due to corruption and damage to the original chip, (my fault) did not discharge capacitor. John |
#883 |
City & State: Europe
![]() post foto's of the board
#884 |
Solder Sloth
City & State: CO
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
![]() Piece of s*$#(%t...
I remember having so much trouble making sure that gcc fit everything in flash and got so pissed off when gcc version bumps caused bloat, and it's still a problem... ![]() |
#885 |
![]() i think the good one is 4.8
need to fire up the other box & check. |
#886 |
Solder Sloth
City & State: CO
![]() I was pissed off that I kept 3.3.something for a long time because it produced the smallest code...
Alas had OS compatibility issues as it was kept back for so long and forced to delete it. |
#888 |
![]() test these - let me know which gives you a display.
that's all its for btw, determining how the display is wired. |
#889 | |
My Country: england
![]() Quote:
John |
#890 |
![]() good, now go into the contrast menu if you can, and find the best setting
#891 |
My Country: england
#892 |
![]() long press / short press combinations should work - sort of.
#893 |
My Country: england
#894 |
My Country: england
![]() If I press the button once it goes into test and then this screen with no component connected and stays like this until battery is disconnected.
John |
#895 |
![]() when it's off, hold the button down.
you will get a menu, or it's not enabled - i didnt check. |
#896 |
City & State: Bacau
My Country: Romania
Line Voltage: 230V 50Hz
![]() Same board as TEDDIBEAR have.Except crystal at 16MHz.
Replaced push button with encoder. Tested few versions,some no display,some display OK but only push button works no encoder. Finally found this one https://www.mikrocontroller.net/svnb..._T3_T4_st7565/ But crystal on board was already 16MHz so display double value. Change value in makefile and works fine. |
#897 | |
My Country: england
![]() Quote:
John |
#898 |
![]() the test i posted is 16MHz, it was to see how the display was wired.
#899 | |
![]() Quote:
now i know how your display is wired, i can make a "real" firmware later. |
#900 | |
My Country: england
![]() Quote:
any help would be appreciated. John |
Thread Tools | |
