ESR meter upgrades
This is a sticky topic.
    • 30951
    Re: ESR meter upgrades
    yes, blue and other similar bob-barker based designs wont show leakage.
      • Jul 2011
      • 6027
      Which ones would show you leakage that are worth a crap
      Please show website links thanks
        • 30951
        pretty much all of the atmel based component testers - they all use the same software
        • snapper1234
          • Nov 2015
          • 2
          • germany
          #984
          Hello
          search (original) working HEX/EEP files and Fuse settings for the GM328 (AY-AT)
          Transistor Tester (from Banggood) because my Atmega is broken.
          The original seems to be protected against reading :-(
          TX7014DH is on the Display,
          thanks for a feedback
            • 30951
            why original?
            we have newer ones on this forum if you search - i know because i built and posted them!
            • snapper1234
              • Nov 2015
              • 2
              • germany
              #986
              which one is to be recommended that comes near to the original?
              where can i download it?
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #987
                https://yadi.sk/d/yW8xa5NJgUo5z
                Inside folder: M328KIT+TFT
                You can there find Firmware in original.
                But also both Madires (M-Firmware) and Karl-Heinz Kübbeler (K-Firmware)
                Note that the "original" firmware is of course the K-firmware with some changes by the Chinese, but not releasing the source code
                If you prefer to build the firmware from source here is the SVN repo:
                The latest K-firmware: https://www.mikrocontroller.net/svnb...oftware/trunk/
                The latest M-firmware: https://www.mikrocontroller.net/svnb...ftware/Markus/
                EDIT: You also cross-posted here and got a reply already from Madires:
                https://www.eevblog.com/forum/testge...16/#msg3119216
                • redwire
                  • Dec 2010
                  • 3900
                  I found the firmware does not detect PNP germanium transistors. They get reported as a diode.
                  Another 328 tester (2x20 LCD) I built with Karl-Heinz Kübbeler firmware does work and tests the transistors OK.
                  This is on AY-AT/ST7735 20MHz xtal with SVN810 STJ.
                    • 30951
                    maybe i should do a fresh build?
                    • Dutch52
                      Retired
                      • Aug 2016
                      • 9
                      • Netherlands
                      #990
                      That would be nice, STJ
                      • lz4pa
                        • Nov 2020
                        • 7
                        • Bulgaria
                        #991
                        I'm new to the forum and I managed to do my tester, but I have a problem with the version. The font is very small. Can anyone help with the .hex and .eep files ?
                        • lz4pa
                          • Nov 2020
                          • 7
                          • Bulgaria
                          #992
                          the my version is AY-AT ESR tester(SVN810) with 16Mhz quartz
                            • 30951
                            i dont have that model to test the different font options.
                            • lz4pa
                              • Nov 2020
                              • 7
                              • Bulgaria
                              #994
                              I made the model M328kit + 1.8''TFT Full Color LCD Display Module 128X160 Serial SPI ST7735S. I just had one. It works great with your software, but unfortunately the font is small.
                                • 30951
                                well you could try making your own.
                                you need the avrgcc compiler and associated tools.
                                i think those are in the arduino suit.
                                or use a Linux machine
                                • lz4pa
                                  • Nov 2020
                                  • 7
                                  • Bulgaria
                                  #996
                                  Thanks for your attention stj. I don't understand anything about programming. That's why I asked for help in the forum. For now I am freezing the project or I will seek help again! Thanks again!
                                    • 30951
                                    yes,
                                    the problem with changing fonts is that you need to take into account the shorter number of characters you can fit onscreen so it doesnt wrap or make a mess.
                                    • lz4pa
                                      • Nov 2020
                                      • 7
                                      • Bulgaria
                                      #998
                                      I won't be able to do it.
                                      I stay like that. If anyone can help me , I will be very happy!
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        #999
                                        This is something you etched yourself lz4pa by the looks of it? Nice work!
                                        What MCU did you use, Atmega328p?
                                        Maybe I will have some time in the weekend to see if something can be improved.
                                        I did not find a firmware for ST7735S display in the massive eevblog thread but I did not look very hard...
                                        • lz4pa
                                          • Nov 2020
                                          • 7
                                          • Bulgaria
                                          #1000
                                          Hello Per Hansson! Yes ,use atmega328p in this construction. I made the scheme of M328 kit + tft display based on st7735s. I guess it's all due to the difference in the resolution of the displays. Thanks in advance!
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
