Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 04-02-2016, 11:04 AM   #121
stj
stj's Avatar
City & State: Europe
Default Re: ESR meter upgrades
you solder the 6pin / 10pin header to some pins under the socket and hook the usb programmer to it.
then you open a shell / console with avrdude installed.
http://download.savannah.gnu.org/rel...de-doc-6.3.pdf
and type or cut-n-paste this.
avrdude -c USBasp -P usb -p m328p -U flash:w:TransistorTester.hex \-U eeprom:w:TransistorTester.eep \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
that's all.
Old 04-02-2016, 11:23 AM   #122
xelectech
retired tech
City & State: NC
Line Voltage: 240/120VAC single phase 60hz
that's all.
I must have been editing my last while you were replying.
I sure appreciate your help, I'll have to do some reading up on avrdude.
xelectech is offline   Reply With Quote
Old 04-02-2016, 02:30 PM   #123
stj
stj's Avatar
can you ask the sellers for a copy of the makefile.
they are obliged to share it under the open-source license anyway.
i want to compare it to the one i just put together.
Old 04-02-2016, 03:24 PM   #124
xelectech
retired tech
City & State: NC
I'm afraid I can't - the last time I sent an email trying to get help from them they sent it back as undeliverable, before that they (she? I suspect it's a one person operation) was non-responsive to my questions and there were no links listed for either troubleshooting,
faqs or software for it. At the end of calibration it says it's v 1.12. Here's a link if you want to have a look around:
http://electronics-diy.com/store.php...&sub=esr_meter
Old 04-02-2016, 04:10 PM   #125
stj
stj's Avatar
there are currently 664 versions of v1.12k
Old 04-03-2016, 07:00 AM   #126
xelectech
retired tech
City & State: NC
No kidding? Where they at? (just kidding) Any of the titles sound even vaguely related to electronics-diy?
Old 04-03-2016, 11:14 AM   #127
stj
stj's Avatar
i mean sequential updates on each other!
https://github.com/svn2github/transistortester
Old 04-03-2016, 01:28 PM   #128
stj
stj's Avatar
i now have a test-build for e-diy, let me know when you have a cpu & crystal
you may want to replace the regulator with a MCP1702-5002E/TO aswell
Old 04-03-2016, 03:05 PM   #129
xelectech
retired tech
City & State: NC
Cool! Where did you find that at? Is it much, or any, different from what's initially running on the newer ones (like you've got)?
Anyway, thanks, it'll probably be a few weeks before I'm set to update this thing
Old 04-03-2016, 03:39 PM   #130
stj
stj's Avatar
i didnt find it, i made notes from the crappy schematic and then adapted the makefile to get close to it.
16x2 lcd
no contrast control
no power control
no crystal
strip-grid pinout
no v-ref
bat monitor is standard.
Old 04-04-2016, 05:21 AM   #131
xelectech
retired tech
City & State: NC
Most ingenious; however, I was hoping you'd found your way into the inner realms of e-diy. Oh well, probably not missing much...
Actually, there is a contrast pot, it's called p1 and is 10k
Old 04-04-2016, 10:37 AM   #132
stj
stj's Avatar
i know that, the note was refering to software control.
Old 04-04-2016, 01:57 PM   #133
xelectech
retired tech
City & State: NC
Oops, beg your problem...
I'm curious, does that (contrast info) go in the file and it may be commented out, or not, depending on the kind of LCD it has? just wondering how different the software is between the two versions of meter.
Old 04-04-2016, 02:12 PM   #134
stj
stj's Avatar
if you downloaded any of those zip's - look at the included makefile for the options.
Old 04-05-2016, 05:20 AM   #135
xelectech
retired tech
City & State: NC
I think I have a mental block or something, it all looks rather daunting, what with three different kinds of files that all seem somehow to be related to the actual program, if it wasn't for utube I don't think I'd have any chance at all of ever getting any thing programmed, at least not without going back to school.
That being said, I got an Arduino Uno so I'm wondering what you think of this link:
http://www.instructables.com/id/AVR-...-gcc/?ALLSTEPS
I figure it would be handy to have the means to make some kind of custom controller set up for a few motion sensors and cameras once I'm thru messing with the
esr meter.
Old 04-05-2016, 11:27 AM   #136
stj
stj's Avatar
if you want to learn to program wih an arduino,
first rule - dont play around, take it serious.
learn some C and go here:
http://www.codeblocks.org/
when you run out of power (your arduino that is!), get one of these 32bit monsters:
http://www.st.com/web/catalog/tools/...N1847/PF262063
they only cost $10 !!!
Old 04-05-2016, 05:20 PM   #137
xelectech
retired tech
City & State: NC
Let me guess, the more I play around the more costly it'll be? Anyway, thanks for the links,
seems odd that a 32 bit controller can be so cheap, it doesn't look like they're from China.
Old 04-05-2016, 05:45 PM   #138
stj
stj's Avatar
no, $10 gets you a 32bit board with built in usb programmer / debugging port.
all software is free.
it's simple, ST is making the boards to sell at cost to get designers to design stuff with their chips and not atmel or TI's
$17 get's one much more powerfull with 144pins and onboard ethernet!!!
not that most people would use either - so go with a $10 type.
Old 04-06-2016, 12:49 PM   #139
stj
stj's Avatar
opto-isolater adapter just got posted
File Type: pdf ComponentTester-Opto-Coupler-Adapter.pdf (11.5 KB, 62 views)
Old 04-29-2016, 08:19 PM   #140
bc989
City & State: My
My Country: Asia
Line Voltage: 230VAC 50Hz
i'm not sure why 3 people downloaded the T4 code without posting answers to my questions afterwards - that code is not tuned or complete!
I'm very keen to upgrade to your T4 code and provide answer. Can it work on my "LCR-T4 Graphical Multi-Function Tester"?
It display "MTester" only, no version number, no branding, no words, letters or numbers to ID it... like a nameless clone of a clone.
I also ordered a 40cents rotary encoder:
http://www.aliexpress.com/item/1pcs-...655246773.html
bc989 is offline   Reply With Quote
Badcaps.net Technical Forums 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
