ESR meter upgrades
This is a sticky topic.
  • bc989
    • Oct 2015
    • 21
    • Asia
    #161
    Re: ESR meter upgrades
    Originally posted by stj
    can you double-check those pads, they use that to program them after assembly.
    Looking at the schematic and comparing to different high-res T3/T4 on google image is making me think my clone got the RESET connection wrong.
    I attach 2 better pics to show difference. The 2nd pic (mine) has a via that goes to pin 30 that other T3/T4 don't use.
    Thinking I should cut and reroute it to the correct pin 29.
      • 30937
      there are a few bad points on that board.
      i would replace the TL431 with an LM4040, and use a 3v3 regulator instead of the pair of diodes top-center.
      • bc989
        • Oct 2015
        • 21
        • Asia
        #163
        Thanks, hope a stable 3v3 will stabilize the LCD and fix the flickering while testing.
        Also got the rotary encoder (green color) why it needs so much force to push down compared to original button? Surely sore fingers after many component test. Are rotary encoder this hard to press?
          • 30937
          you dont want it geting pressed by accident.
          and it's intended to have a knob fitted.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #165
            stj is this kit ok in your opinion
            http://www.ebay.co.uk/itm/3318737413...%3AMEBIDX%3AIT
              • 30937
              looks about the same as the banggood one, cant tell if either have protection diodes though.
              but the price is very good.
              i still cant understand why the chinese arent using 16MHz crystals yet.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #167
                cheers i will order one its in a kit form so will give me something too do can these be upgraded?
                • bc989
                  • Oct 2015
                  • 21
                  • Asia
                  #168
                  stj, finally got to test your 'T4 ESR tester (testing v1).zip' from page 6. Its not compatible on mine, just a blank screen.
                  The ones from the russian site are not working too.
                  Only after trying some more on https://github.com/svn2github/transistortester did I find 3 that displayed something except its all flipped, mirror vertically and horizontally in all ways except the right way. The one that is still readable upside down is "mega328_st7565".
                  Guess I need to play with the Makefile and compile it myself.
                    • 30937
                    blank screen could be the contrast setting - i had that issue when i started doing this stuff.
                    about upgrading,
                    the biggest upgrade is probably the crystal.
                    a 16MHz crystal means you can also test crystals and resonators upto about 12MHz
                    other than that,
                    replacing the 1117 / 7805 regulator with an mcp1702 lets you run the living hell out of the battery until it's only got about 5.6v left in it!!
                    replacing a zener diode or 431 voltage reference with an lm4040 will increase accuracy.
                    the other thing i'm working on - a relay that switches a cap across the socket for testing small inductors.
                    sounds simple, but the cap must be stable - mine is 2%, and the relay should have a magnetic shield or it will mess with the inductor being tested.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #170
                      so when i get mine i will take measurements of the crystal and voltage regulator and order upgrades do i need to programme the board for the crystal to work correctly?
                      • GoNz0
                        • Sep 2012
                        • 28
                        • United Kingdom
                        #171
                        about upgrading,
                        other than that,
                        Will I be able to do all this with the banggood kit?
                        Thanks.
                          • 30937
                          to both of you - yes.
                          the normal crystal is 8MHz, you just swap it out.
                          same with the regulator and reference - although you need to check the pinouts to get the replacement the right way around.
                          if you change the crystal, you need to change the software.
                          • bc989
                            • Oct 2015
                            • 21
                            • Asia
                            #173
                            Ok for my unknown nameless Mtester clone, I got the display back by removing from your Makefile, just this one line:
                            Code:
                            CFLAGS += -DSTRIP_GRID_BOARD
                            also to stop the compiler from choking, had to change function_menu.c line 133 to:
                            Code:
                            [COLOR="Red"]uint8_t[/COLOR] function_menu() {
                              • 30937
                              strange, you talking about a compiler warning or a compiler error?
                              • bc989
                                • Oct 2015
                                • 21
                                • Asia
                                #175
                                This is what it showed, pointing to function_menu.c, so I simply changed it.
                                Code:
                                $ make
                                avr-gcc -Wall -DWITH_MENU -DWITH_CONTRAST -DWITH_ROTARY_SWITCH=2 -DCHANGE_ROTARY_DIRECTION -DFOUR_LINE_LCD -DLCD_ST7565_H_OFFSET=0 -DVOLUME_VALUE=48 -DFONT_7X12 -DICON_TYPE=3 -DBIG_TP -DSTRIP_GRID_BOARD -DWITH_SELFTEST -DAUTO_CAL -DWITH_UJT -DWITH_PUT -DWITH_AUTO_REF -DREF_C_KORR=12 -DREF_L_KORR=40 -DC_H_KORR=0 -DWITH_UART -DRMETER_WITH_L -DCAP_EMPTY_LEVEL=4 -DAUTOSCALE_ADC -DREF_R_KORR=3 -DESR_ZERO=20 -DNO_AREF_CAP -DUSE_EEPROM -DPULLUP_DISABLE -DANZ_MESS=25 -DPOWER_OFF -DBAT_CHECK -DBAT_OUT=3 -DBAT_POOR=6400 -DBAT_NUMERATOR=133 -DBAT_DENOMINATOR=33 -mcall-prologues -DLCD_ST_TYPE=7565 -DLCD_ST7565_RESISTOR_RATIO=4 -DF_CPU=8000000UL -DMHZ_CPU=8 -mmcu=atmega328p -gdwarf-2 -std=gnu99 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT function_menu.o -MF dep/function_menu.o.d -DSamplingADC -c ../function_menu.c
                                ../function_menu.c:133:6: error: conflicting types for 'function_menu'
                                 void function_menu() {
                                In file included from ../Transistortester.h:12:0,
                                         from ../function_menu.c:5:
                                ../tt_function.h:49:9: note: previous declaration of 'function_menu' was here
                                 uint8_t function_menu();  // menu for selecting extra function
                                make: *** [../finish.mk:13: function_menu.o] Error 1
                                Fyi I'm using Atmel toolchain.
                                  • 30937
                                  what gcc version?
                                  • bc989
                                    • Oct 2015
                                    • 21
                                    • Asia
                                    #177
                                    avr-gcc.exe (AVR_8_bit_GNU_Toolchain_3.5.2_1680) 4.9.2
                                      • 30937
                                      hmm. i'm using 4.8.1
                                      you need to be carefull, the newer versions create larger files.
                                      upload your makefile.
                                      • bc989
                                        • Oct 2015
                                        • 21
                                        • Asia
                                        #179
                                        Yes its bigger by a bit.
                                        ok Makefile attached with that 1 line remarked out and the hex/eep in case anyone with the same model as mine wants to try.
                                          • 30937
                                          is the contrast right, or do you have to fine-tune it from the menu?
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
