Dim Clock LCD on Jenn-Air wall oven
  • bluto
    • Oct 2007
    • 560
    #81
    Re: Dim Clock LCD on Jenn-Air wall oven
    Post some pictures. It may be possible to see what is wrong. Also double check the obvious things like making sure the connectors are all securely connected and oriented in the right direction.
    • davnjax
      • Jul 2012
      • 9
      • usa
      #82
      I am new to this forum. I replaced the C3 capacitor in my Jenn Air wall oven board (modelww27430p). Before the replacement, the oven would work even though there was no display to show the temp, etc. The clock displayed dimly. After the repair I can't get oven to even start, nothing beeps when I press the buttons to start a function and no clock. I tested the extra 68uf 35v capacitor (purchased from DigiKey) and get the same ohm reading with both the unused capacitor and the one on the board so it would seem that the one on the board is connected. Any suggestions on what I can do next to fix this issue? I purchased all the capacitors listed in one of the first messages in this thread. I am confident of the polarity on the capacitor as the orientation is the same as it was originally.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Check to make sure all the connectors are connected up tightly.
        Muh-soggy-knee
        • davnjax
          • Jul 2012
          • 9
          • usa
          #84
          I have reconnected and all seem to be tightly coupled. I even had a friend check to see if he could find something easy that I had missed on the connections. My first reaction is that the ribbon cable isn't connected but that seems tight as well. The oven light on the exterior input panel does control the oven light, not sure if that goes through ribbon cable and board.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Maybe you have a bad solder joint somewhere on the board.
            Muh-soggy-knee
            • davnjax
              • Jul 2012
              • 9
              • usa
              #86
              The capacitor seems tight as do the other connections on the board. I'm wondering if my problem is the ribbon cable because that connects the board to the touch panel. How do I know that the cable is well seated (pushed far enough in)? Also, is there a fuse that I might have popped because I'm thinking I disconnected or connected when the power was on once. I have attempted to attach a picture of the soldier joints. The joints aren't as flat
              on the board as the originals - is that my problem? Is there a way I can get them to flow to the board better?
              Thanks, Jackie
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Thanks, Jackie
                Ah! no wonder why it isn't working, you broke a copper trace.
                Muh-soggy-knee
                • davnjax
                  • Jul 2012
                  • 9
                  • usa
                  #88
                  where is the broken copper trace (trying to learn, not questioning your response). Does this mean I just anty up and buy a new board? I'd really like a working oven even if I have to pay the price. And, how do I avoid breaking a copper trace - I want to fix my daughter's oven and not mess it up like I did mine
                  Thanks, Jackie
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Thanks, Jackie
                    Here it is. Just use a thin piece of wire (like from a component lead) to bridge the gap there, and solder it in good. That should fix your problems!
                    Muh-soggy-knee
                    • bluto
                      • Oct 2007
                      • 560
                      #90
                      Some more advice that is given often on this site: Find some other electronic device that is no longer working and practice soldering on it. Remove some of the components and re-solder them back in place. Your joints should look like all the others. Once you are more comfortable with your soldering skills, then you can make another attempt on the piece that you are trying to fix.
                      Try watching some youtube video videos on soldering too!
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        I have a few good ones on my channel I made a while back:
                        Capacitor installation: http://www.youtube.com/watch?v=Op-UQLcH5Rc&feature=plcp
                        Desoldering braid usage: http://www.youtube.com/watch?v=2L4iv_m0ZgE&feature=plcp
                        Radio shack desoldering iron usage: http://www.youtube.com/watch?v=Bt5liP59jBY&feature=plcp
                        There is another method I like using a thin metal pick... sometime I'll have to make that video using my special "solder cam" rig I built.
                        sigpic
                        (Insert witty quote here)
                        • davnjax
                          • Jul 2012
                          • 9
                          • usa
                          #92
                          Thanks for the advice. I have bridged over the bad copper trace. Now the top oven is working but no display or lower oven function. I'm wondering if the ribbon cable is not seated quite right. Great advice on practicing on an old board and watching you tube videos. I'm sure practice will help. I'm not ready to give up so will try what you've suggested.
                          I'm retired now and used to have the benefit of working with wonderfully talented technical people that could point me in the right direction to fix/resolve problems. This forum is wonderful, thanks so much.
                          Jackie
                          • bluto
                            • Oct 2007
                            • 560
                            #93
                            The solder joint on the other side of the capacitor doesn't look too good either. You might want to touch it up too. Hopefully doing that will bring life back to your clock.
                            • davnjax
                              • Jul 2012
                              • 9
                              • usa
                              #94
                              Thanks to this forum my oven now has a display, etc. This was wonderful. Now I'm wondering how I could figure out if there is a bad capacitor in my other jenn air oven. I can't adjust the temp on that oven. That oven doesn't get as hot as it should. There are steps to input and bump the temp by 5 degree increments but they don't work. Jenn Air says I need a new control board so for now I'm setting the temp 20 degrees higher than I want to circumvent that problem.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Are you sure the heating element is not worn out?
                                Open it up and have a look inside
                                Muh-soggy-knee
                                • davnjax
                                  • Jul 2012
                                  • 9
                                  • usa
                                  #96
                                  I had the local appliance repair company try to "fix" the oven. He has a good reputation and has been great on other things. He called Jenn Air when he was working on the oven because it would not register the temp increase he was trying to enter. Jenn Air tech said it needs a new board. I had installed a new thermostat and element prior to that service call but it made no change in the oven temp so I think we can rule out a bad element. The oven is in my vacation rental, when I get an open day I'll open the cover and check for bulged capacitors, etc so your comment to open it up and have a look is a point well taken. Thanks!!
                                  • jmcbrg
                                    • Jul 2012
                                    • 2
                                    • US
                                    #97
                                    I also have the dimming LCD problem, Jenn Air SVD48600W model. Mine continued to get worse and worse, just like everybody else's but before seeing this forum I ordered a replacement clock module. I replaced it, it worked for about a week then that one went completely dim. The place where I bought the module sent me a replacement at no cost, but before I put it in I wanted to see if anyone knows of any other reason this could be happening. I realize the module they sent could have been faulty (it looked for all the world like a used piece; even felt a bit greasy as though it had come out of a different range rather than new). All the functions still work fine, controls the stove, everything beeps as it should, but the clock is dimmed out completely. Is there an additional board that I should be investigating?
                                    --Jeff
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      --Jeff
                                      Nope, there still is an issue with the board! Have you ever soldered before?
                                      @davnjax:
                                      If the caps aren't bulged its still a good idea to replace them, they can go bad without bulging!
                                      Muh-soggy-knee
                                      • jmcbrg
                                        • Jul 2012
                                        • 2
                                        • US
                                        #99
                                        Yes I have, but as I say I already have another replacement board in hand from the company I bought the first one from; I was just hesitant to install it for fear the actual problem was on some power supply board earlier in-line and it would just pop this one as well... at this point I'd just as soon replace the whole thing and be done. The first one I got from them was suspicious to start with, it wasn't in a box and it felt a bit greasy, so I wondered if it had come out of a used range somewhere. When I mentioned that on the phone the woman said, no, we would never d that and all our parts come new in the box. I told her this one hadn't and that it failed, she said I'll send another right out, she did and this one indeed was in a box and new. So I'll give it a shot.
                                        • bluto
                                          • Oct 2007
                                          • 560
                                          #100
                                          I am sure it is possible that there is something else afoot.... But as you said yourself, the oven works fine, all controls are functional, just a dimmed out display. This matches the symptoms that my oven had and just about everyone else that posted in this thread. I don't think anyone here claims to be an whirlpool-based oven expert, so I don't think you are going to get an alternative explanation for this issue on this forum. If you are worried about this second replacement, why not gamble $ to replace the capacitor on your original clock? You really don't have anything to lose. If it works you can send the replacements back to this shady sounding company and get the $$$ that you spent on it back.
                                          • asuwish824
                                            Jenn Air Wall Oven Dim LCD
                                            by asuwish824
                                            I recently purchased a Jenn Air Wall Oven model number jjs2730ws00. It functions properly except that the lcd display is rather dim. No adjustment in the settings seems to improve or even change the dimming/brightness of the display. My hope is I can repair the current display instead of purchasing a new or used unit to replace. I prefer to fix at the lowest point for the joy of the repair. Also throwing out what would otherwise be a perfectly good part just because perhaps a capacitor or other small part is bad seems obviously wasteful. Any guidance would be appreciated.
                                            PS It...
                                            05-18-2022, 10:30 PM
                                          • Fsufan1391
                                            LG Oven model LREL6325F
                                            by Fsufan1391
                                            Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                                            04-23-2025, 05:42 AM
                                          • Joe24
                                            Maytag Whirlpool Kenmore clothes dryer data bus
                                            by Joe24
                                            Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                            Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                            I've been over the board looking for...
                                            01-13-2025, 06:50 PM
                                          • bpjl
                                            SEF 551.10 - Error starting the reflow oven.
                                            by bpjl
                                            When starting the SEF 551.10 reflow oven, the following problem occurs:
                                            It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                                            PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                                            10-17-2024, 06:30 AM
                                          • goodpsusearch
                                            Daewoo microwave oven repair
                                            by goodpsusearch
                                            One day my microwave oven stopped heating.
                                            It would turn on and rotate the plate but no heat.
                                            I removed the cover and checked components with digital multimeter.
                                            Found that the high voltage fuse was blown.
                                            This is not the AC fuse, if the AC fuse was blown then the oven would appear totally dead.
                                            Then I tried to find replacement fuse on local electronic parts stores and this specific value was not available so I got the closest I could find.
                                            I replaced fuse and tried to heat up a glass of water.
                                            Strange noise...
                                            01-24-2021, 03:56 PM
