the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    #261
    Re: the gutless, bloated, and fried power supply hall of shame
    Not arguing that, though I wonder how hot they are in an AC adapter when the AC adapter only feels scantily warm (I guess there's no way to find out)?
      master hoarder
      • May 2008
      • 12164
      • Bulgaria
      #262
      Originally posted by Heihachi_73
      King World Enterprises, Proprietary Limidet(?!).
      Hmm... let's see if we can decipher this one...
      - Mismatched diode sizes on the bridge rectifier - CHECK
      - "7700" marks on the 5vsb transformer - CHECK
      - very shitty built quality - CHECK
      Looks like a Sun Pro or Powmax/Leadman to me. The worst of the worst really (or is it the best of the worst?). I'm surprised they put in a 30A schottky on the 5V rail though. How generous! Too bad the 12V rail "schottky" is only that "diodes-on-a-bracket" crap.
      Mmmm Rulycon... They fail without bloating most of the time, they just dry out
      That's the exact opposite of what I have seen. All of mine have bloated, even the ones that weren't originally and were just sitting around.
      I'll take your word, though. Rulycon is such a pile of crap that I wouldn't be surprised if we are both right .
      Originally posted by b700029
      I have a 95W laptop AC adapter and its transformer is qutie a bit smaller.
      That's different, though. Quality power adapters can get away with smaller transformers because they use a higher switching frequency. With a quality transformer, they can get much higher efficiency as well. Some even use synchronous rectification as well (instead of rectifying diodes, they put MOSFETs that switch ON only when there is a positive pulse to rectify) - those can easily get in the 90% efficiency. Ever cracked a PS3 power supply? Those use tiny transformers. Yet, due to their higher switching frequency and sync. rectifier design, they can push upwards of 350W without too much cooling.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Originally posted by Agent24
        I worry a bit about my Toshiba's power adaptor though. There are no vents, and the thing gets damn hot under full load, in fact they even have a warning label on it about it getting hot.
        Mine is like that too, it has a yellow label on it saying that it can get hot.
        Cant wait until it breaks to see whats making it so hot inside I wonder what type of caps are in there too! Mine is a PA-1650-21
        Drawing ~3A at 19v, my computer makes this thing get hot! And the fact that it mostly sits on carpet doesn't help at all!
        Muh-soggy-knee
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          We should design a line of badcaps.net PSUs. With good caps, and synchronous rectifiers
          Muh-soggy-knee
          • Agent24
            I see dead caps
            • Oct 2007
            • 4926
            • New Zealand
            #265
            Mine's a PA-3290U-2ACA rated 19v at a nice 6.5 Amps.
            That's probably because the Laptop is a P4 3.3GHz which is based on Prescott. Yep. Prescott. In a Laptop.
            -David VanHorn
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Haha! yeah, thats much bigger! I got a Phenom II (3-cores) in mine.
              Muh-soggy-knee
              • Agent24
                I see dead caps
                • Oct 2007
                • 4926
                • New Zealand
                #267
                Yours sounds faster, although with HT and 2GB of RAM mine can still hold its own OK. Graphics are a bit sad though - Radeon 9000 - but probably better than an Intel IGP from that era.
                Of course, with the high power, you get high heat too, so mine has two CPU fans, and when you put a good load on the system, you can really hear it
                -David VanHorn
                  master hoarder
                  • May 2008
                  • 12164
                  • Bulgaria
                  #268
                  My sister's old laptop was a Sony Vaio with a 2.8 GHz Prescott. That thing is LOUD! Fans were always on full blast no matter what you did. Except when playing games - then the GPU fan would turn on as well and you'd think there was a jet engine near you. It also had a Radeon 9000 like yours. In all honestly though, that GPU is not too bad at all. It ran CMR 3 okay. Intel's graphics of the time were crap compared to that. Even recent Intel IGPs will probably still struggle with that game - they just suck for games.
                  Surprisingly that laptop never ran too hot though. Neither did the power adapter. Actually calling it a power "brick" would be more appropriate.
                  Just take a Sony PS3 PSU and mod it. You can probably fit 3 in a standard ATX PSU case. Considering each one can do 32A on the 12V rail, that's over 1 kW of power available on the 12V rail. Could make your computer double as a welder .
                  • pdavid
                    • Jan 2011
                    • 279
                    • Hungary
                    #269
                    That gutless Gigabyte psu I mentioned here
                    Fuse, mosfet blown.
                    -some EMI filtring
                    -passive pfc
                    -470 Capxon primary capacitos
                    -10A bridge diode... why
                    -3842 pwm chip
                    -6A mosfet;
                    -ERL 35 trafo
                    -12V: sbr10200; 5V: mbr2040; 3,3V:2040
                    -some weltrend supervisor
                    -ntc on heatsink
                    -tiny capacitors, missing filter coils;
                    I think it could be usefull after a full rebuild though.
                    • Behemot
                      • 4845
                      • CZ
                      #270
                      By coincidence, I found some ASUS which looks similar - at least from outside it had also black stick, similar heatsinks and 80mm fan. Will try to get my hands on it
                      • b700029
                        Banned
                        • Sep 2010
                        • 640
                        #271
                        Originally posted by pdavid
                        -6A mosfet;
                        Only one? That's probably good for 180-200W at most.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Low end Gigabyte PSUs aren't that good. I posted one on post 119 of this thread with half a PCB and miniscule heat sinks
                          • Behemot
                            • 4845
                            • CZ
                            #273
                            OK guys. I couldn't resist and opened intelligence module for our Symmetra LX 16k UPS. It was suspicious that it dies, well, not dies, becomes to behave strangely every like 2 or 3 years. Of course there are four bulged caps (T.I.C. brand) on its power supply part.
                            If this will be the only problem - and I bet it will - I just saved worth 640 E / 780 USD.
                            Just how the sucks use Chemi-Cons on the parts where it could die in less than 2 years where they would have to change it under warranty!!
                            ADD// Guess what? It works!! This is one of the worst cases of fraud I have ever seen. Yes, I heard botu the plasma TVs, but never had them in my hands. This, I had. And the price is pretty much the same.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              I bet no one thought a Delta would ever end up on here, but today I have just that - a destroyed delta. THe fan was branded T&T (Thieves & Thugs ?) and it quit. Here's the carnaige. The PCB discolouration didn't show up quite as clearly in the photos as I'd hoped, so if it looks slightly discoloured in the photo, it's really bad in real life. The cool part is, it still runs, albeit with very high ripple due to all the bad caps. I'm thinking it might be salvagable by replacing the caps, fan and secondary torroids.
                              • Wester547
                                • Nov 2011
                                • 1268
                                • USA.
                                #275
                                How did it (almost) murder itself like that? Is it the tan/brown glue? Placement of diodes? Or something else?
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  The fan quit, as I said, and it lacks OTP
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #277
                                    Oh yeah, it is pretty bad even on the foto (in comparison with Pentium's photos ). I get the feeling I should check and lubricate every fan in every PSU going through my hands from now on…?
                                    • Wester547
                                      • Nov 2011
                                      • 1268
                                      • USA.
                                      #278
                                      Whoops, I don't know how I missed that. ^^; No surprise that cheap sleeve bearings seize sooner than late. I'm surprised it could still start up given all the capacitors were bloated (usually the capacitors on the 5VSB rail prevent a system from posting whence they fail).
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        WOW, that thing really fried up!
                                        I laughed at how the one taicon is not vented, and the rest (capxon and ltec) are :P
                                        Muh-soggy-knee
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          It's probably just dried out. Given the amount of heat discolouration, I wouldn't blame a Panny for failing.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
