Thread Tools |
#281 | |
I see dead caps
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
![]() Quote:
Certainly bloated and fried though! ![]()
"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous" -David VanHorn |
#282 |
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
![]() CapXon and Ltec would fail anyway... note the unbulged Taicon, those actually seem like OK caps, haven't seen any fail YET. It's less ambient temperature and more ripple current that kills crap caps.
Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead! Free service manuals: http://www.toms-service-manuals.com/ -- 72 LED/LCD TVs, 5 monitors, 28 plasma TVs, and 2 AVR 6.1 amplifiers fixed! -- I repair Pioneer 9G Plasma Main Boards & KRP-M01 Media Receivers (PM me for info) 2 Pioneer KURO 9G, 12 Panasonic LCD/Plasma, 1 Sony LCD, 1 NEC Plasma, 2 Yamaha HTS, 5 Sharp LCDs, 5 Toshiba LCDs, 7 Philips Plasma/LCD, 1 Hitachi Plasma, 11 LG LCD/Plasma, 18 Samsung LED/LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Grundig LCD, 1 Dell LCD, 1 iiyama LCD, 1 Acer LED, 1 Logik LCD, 1 Baird (China) LCD, 6 Bush LCDs, 22 Vestel LCDs (Best->Worst) |
#283 |
My Country: Australia
Line Voltage: 240V 50Hz
![]() I removed the caps today, and I got a photo with some better light. Now you can really see how bad the heat discolouration is
EDIT: I also took the failed fan apart, and I think there was more to this than just bad sleeve bearings. It looks like there was lots of rust around the magnet on the blade housing and on the motor
I love putting bad caps and flat batteries in fire and watching them explode!! No wonder it doesn't work! You installed the jumper wires backwards ![]() Main PC: Core i7 3770K 3.5GHz, Gigabyte GA-Z77M-D3H-MVP, 8GB Kingston HyperX DDR3 1600, 240GB Intel 335 Series SSD, 750GB WD HDD, Sony Optiarc DVD RW, Palit nVidia GTX660 Ti, CoolerMaster N200 Case, Delta DPS-600MB 600W PSU, Hauppauge TV Tuner, Windows 7 Home Premium Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro Last edited by c_hegge; 09-07-2012 at 12:45 AM.. |
#284 |
City & State: Prague, 50°4'52.22"N, 14°23'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
![]() Not nice, really. In some worse fans when sometimes the magnet tends to rub against motor I lubricate it with vaseline. Maybe if you will clean it you can as well use itfor conserving again corosion.
Less jewellery, more gold into electrotech industry! ![]() ![]() Exclusive caps, meters and more! Hardware Insights - power supply reviews and more!
#285 |
![]() I probably won't worry. I have a few spare Yate Loon fans which are in much better condition, so I'll probably just replace it with one of them
EDIT: I probably should also add that the plastic washer which holds the blade housing to the motor crumbled when I took the fan apart. Last edited by c_hegge; 09-07-2012 at 04:37 AM.. |
#286 |
I see dead caps
![]() I wonder if the rust is what jammed it?
Looks like you forgot to desolder the leads of C103? |
#287 |
My Country: CZ
#288 |
CapXon Be Gone
City & State: Idaho
Line Voltage: 120VAC 60Hz
![]() R.I.P. to that Delta. That thing is SCORCHED!!!
#289 |
City & State: CA.
My Country: USA.
Line Voltage: 120-125VAC 60Hz.
![]() If that power supply lacks protection circuitry of any sort, that may be why it still works with bloated capacitors.
#290 |
![]() That one really didn't want to come out (maybe due to the generous use of glue on that leg). The other leg broke was I was trying to bend and twist the cap out of there.
#291 |
My Country: CZ
![]() Pliers?
#292 |
Yes |
#293 |
City & State: Gloucestershire
My Country: England
Line Voltage: 240V 50Hz and proud of it!
![]() There's me happily using my old Apple PowerBook 1400, then the next time I come to use it, nothing. So I open up the little brown brick (the official power supply) and was amazed to discover the destruction shown in the pik. I have no idea what caused it.
#294 |
Capaholic
City & State: Trenton, NJ
Line Voltage: 240/120V 60Hz
I'm a: Hardcore Geek
![]() Looks like a diode and two resistors burned.
Muh-soggy-knee |
#295 | ||
master hoarder
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
![]() Quote:
Although likely salvageable if you cared enough to fix it. I would - extra spare junk fans for the random project never hurt. Sandpaper and a bit of oil is really all you need. When I find a fan that has started to get rust on the stator, I just lube it with machine oil. Last edited by momaka; 09-09-2012 at 05:05 PM.. |
#296 |
My Country: CZ
![]() As I stated, I use vaseline, it is better I think. Oil just vaporizes or dries out due to absorption in dust. Vaseline is more durable I think and lubricates even full of dust.
#297 |
![]() I have a large box full of spare fans. I only ever keep really good fans nowadays.
#298 |
City & State: NY
![]() Here is an 8 years old Antec that was still running, though a bit unstable. Nice collection of toasted caps awaits:
#299 |
My Country: CZ
![]() What model is that?? Looks like some very old topology.
#300 |
I see dead caps
![]() Looks pretty good apart from the Fuhjyyu crap
Thread Tools | |
