the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    #801
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by ben7
    The only good about it is it looks like it has proper Y capacitors ... not regular, unsafe, ceramic capacitors.
    Yeah, no input common mode inductor, no X cap, no MOVs to prevent the input lytics from venting (a safety standards violation, IIRC). Those heatsinks, the MJE13007-copy BJTs, the 470uF input lytics, the TL494, the -26 material output inductors all yell, "I'm a mediocre 250W power supply!"
    [elitist rant] Dammit, the UC384x family PWMs and power MOSFETs have been around for 3 decades, everyone knows who the good cap vendors are, powdered iron cores have been around longer than I have, and heatsinks have been around and understood as long or longer! There is no excuse for manufacturing and selling a TL494-and-BJT-switch-device-and-26-material-based, unfiltered input, wimpy-heatsunk, crappy-fanned, crappy-&-wimpy-capacitor-populated POS like this. Not without a multilingual warning label such as, "Warning: this POS is a waste of money and is hazardous to your checking account, computer system, and home!" [/elitist rant]
    PeteS in CA
    • PeteS in CA
      • Aug 2005
      • 3579
      #802
      Those Chinese PSU names are funny. Though still not as funny as PowMax, IMO.
      Don't know if they're still around, but in the mid-late 80s I came across a Korean power supply company named Torch. Just inspires so much confidence in their reliability. Then there's the classic American power supply company, Acme Electric (Beep! Beep!). In fairness to the latter, they predate Roadrunner cartoons.
      PeteS in CA
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Your post made me laugh Actually, the heatsinks are better than they look. That metal is actually pretty hard to bend with your fingers, I was surprised. I'm not saying they're good, just that they aren't the Leadman style ones that look like they were forged from melted beer cans I can load it up to around 200W and see how hot the toroids get. By the way, what's that third coil doing in there?
        • cheapie
          null
          • Jul 2010
          • 849
          Re: Power Star PS-650
          Originally posted by momaka
          Yes, very important for your SDRAM to have clean power!
          Oh wait, it's not 1999 anymore?
          You realize that we still use SDRAM today, right? (DDR, DDR2, DDR3... it's all SDRAM) I'm not sure if it's still powered from +3.3V though.
          • Wester547
            • Nov 2011
            • 1268
            • USA.
            #805
            That third toroid is required for the magamp circuit on the +5V and +3.3V rails as it derives the +3.3V from the +5V transformer pins (hence the combined rating). You will find it in pretty much every PSU with that design (and possibly another one of those), except for PSUs that use linear regulation (or other kinds of DC-DC conversion) to generate the +3.3V rail.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Cool, thanks for the info. I guess the design of this one just threw me off, the secondary design is a little different than I'm used to seeing. It's amazing that they use these old designs and "semi-upgrade" them. I'm also used to seeing two rectifier slots available on the +5V rail, but that Power Star has another rectifier slot on the +12V rail.
              Even though this design sucks, I wonder how much it would benefit from another +12V rectifier. Although recently I've noticed that a lot of old half bridge PSU's refuse to use schottky rectifiers on the +12V which is unfortunate because they work fine on the +5V and +3.3V
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                #807
                What i meant by SDRAM was that good old classic PC100/PC133 168-pin stuff.
                On crappy motherboards (or maybe even most motherboards and not just crappy ones), it was directly powered from the 3.3V rail, so any instability on the 3.3V rail could make the PC crash.
                The most recent motherboards I've worked on is Pentium 4 S478 stuff and AMD AM2. And even on those, *most of the time*, RAM is powered by the 3.3V rail. However, newer RAM (DDR and newer) is 2.5V or lower, so the 3.3V rail is stepped down - usually either through a MOSFET in a linear fashion or with a synchronous buck regulator. Because of that, ripple/noise on the 3.3V rail rarely affects the RAM (and thus system) stability.
                Buy try hooking a really crappy PSU (i.e. one with no PI filters and insufficient capacitance) to an old motherboard and see what happens. If the motherboard doesn't have a lot of caps near the RAM to filter power from the PSU, you'll probably get lots of rebooting and/or BSODs.
                • Behemot
                  • 4845
                  • CZ
                  #808
                  That was the principle of the design so I don't understant your crap talk.
                  The same, powering by +3,3 V is a must to provide minimum load on +3,3 V rail. Nothing else is drawing power from this rail anymore. I am expecting new ATX revision any day which will most likely increase +12 V even further, exclude -12 V rail and also require the PSU to be able to run with no +3,3 (+5) V load.
                  In the long-term, I expect +3,3 V and finaly also +5 V to be exluded as well, possibly replaced with something like +24 V (for higher efficiency). But it won't be easy and probably will brake backward-compatibility.
                  • mariushm
                    • May 2011
                    • 3799
                    #809
                    You'll have to forgive me for the quality of this post - I'm visiting my parents' place for a few days so I'm demoted from a eight core system with 2 1920x1200 screens to a Sempron pc with a 19" lcd screen.
                    In addition, I've snapped the following pictures with my sister's camera, with batteries nearly dead (literraly turned off and on the camera every 2 pictures due to flash getting the batteries below the threshold).
                    I'm also writing this through remote desktop connection to my pc so if i make grammatical mistakes it's the lag.
                    So please excuse the out of focus and poor quality of pictures, the post,everything, i'm not in my environment.
                    Anyways, on with the story. Father complained a few weeks ago that the system was erratic, not powering on , or powering on only once every few times. Then one day it died.
                    Knowing it was a crappy psu that came with a 30$ case 3-4 years ago when this system was made, i just told him to go with the computer at a local service and let them install a new cheapo psu in the system. He only uses the computer for eBay (collecting stamps and coins) and news.
                    So here's the 400w rated psu. Supposed to be 400w ... based on transformers it looks more like 250w max.
                    Full of CS capacitors, 560uf 200v 85c on primary, 13009 transistors, ie-33 transformer, i think it's the two transistor job for the 5v sb
                    3.3v, 5v, 12v is 22a , 40a, 18a but i doubt it, the beefiest diode that i can see on the heatsink is a SB3040PT which is a 30A shottky barrier rectifier.
                    If you check the pictures carefully, you'll see why it died.
                      master hoarder
                      • May 2008
                      • 12170
                      • Bulgaria
                      #810
                      Dead cap on 5VSB output, looks like. Easy fix. Yeah, it may not be a 400W PSU, but it's probably more than enough for that Sempron PC. Only concern is the 5VSB sections - it looks darkened. I don't see a critical cap on there, though. Perhaps it just needs new output caps on 5VSB (although if you replace the output caps on the rest of the PSU, that wouldn't be a bad thing eitehr).
                      Well, you wondering why cheap PSUs almost always have their 3.3V rail filtering built a little better than the other rails? It's precisely because of that.
                      • mariushm
                        • May 2011
                        • 3799
                        #811
                        Bingo. That schottky rectifier on the secondary also looks a bit cooked, may be dead.
                        Honestly, can't be bothered to carry it with me back to my place and fix it, all i have here are screwdrivers.
                        I would have loved to remove the big caps and measure them, for Uranium's thread, but it's just too much hassle.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          I blew one of those PX-400s up in the 1012 el cheapo PSU roundup. It did 250W in spec, but it was pretty inefficient.
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Still looks better built than the Deer PSUs I had.
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • Behemot
                              • 4845
                              • CZ
                              #814
                              It's been selling like hot cakes under several names here like ten years ago…well, cheap craps is the most sold one, we have to face it
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                #815
                                This thing is not that bad. It needs a full recap and some oil in the fan and then I would check that the caps spins fast enough to keep the psu cool.
                                • Behemot
                                  • 4845
                                  • CZ
                                  #816
                                  I am not really sure…doing like 60 % of rated power (and I won't even guess how much in spec) is not that bad?
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    As I said, it made it up to 250W with everything in spec.
                                    • Heihachi_73
                                      • Jun 2012
                                      • 713
                                      To be fair though, a new PSU form factor would be no worse than the switch from AT to ATX in the 1990s. Even though ATX supported 12V, 5V, -12V (early revisions ATX only) and -5V like its predecessor, it was a completely different connector to the infamous 2x 6 pin AT connectors (where putting in the mechanically-identical connectors the wrong way would result in releasing the magic smoke from your board). I won't get started on Dell...
                                      If a better PSU design means that an old Pentium II or Socket A won't boot with that PSU, so be it. If you were to shove 24V down a mechanically-compatible ATX connector, regardless of which pin was used (well, obviously not GND), your board would go boom anyway. Adding extra pins to maintain compatibility with old systems just makes things more bulkier and expensive, and also forces PSUs to become more cramped inside (if the same standard form factor, also from the late AT era, is used), since they have to support half a dozen different voltage rails as well as the mains input.
                                      • cheapie
                                        null
                                        • Jul 2010
                                        • 849
                                        I don't think it would be that hard to create an "ATX24V" (or "EPS24V") spec, as long as somebody produced compatible motherboards and adapters were available to convert the connectors to SATA and such.
                                        Maybe something like a Molex Mini-Fit Jr. style connector (similar to the current CPU power connectors) would work. It could have five pins in a row - two 24V, two ground, and one for communication (like some sort of 1-wire protocol). All of those connectors would be mechanically and electrically compatible. The power supply would output 24V all of the time, oblivious to whether the computer is actually on. The motherboard would simply instruct devices to power on or off as desired.
                                        I think that the same old form factor would be okay, as having a single-rail supply means no VRMs or anything like that, so there would be more space inside for other parts.
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          What I think would be good idea is to have a universal voltage for all ICs and components (CPU, RAM, GPU, chipsets, etc). That way, the PSU could go directly down to that voltage, and there would be no VRMs on motherboards.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
