the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by mariushm
    later edit 2 : TELVM if you contribute to that site, why the hell does it not allow google translate to translate the forum?
    It translated it for me just fine ...
    Looks like the typical cheap-ish PSU. Those thin heatsinks with holes on the top seem fairly common. And, typical 3A diode bridge rectifier... not bad for low wattage but for higher wattage you want to go with a better bridge rectifier.
    Muh-soggy-knee
    • TELVM
      • Oct 2012
      • 547
      • Spain
      #842
      I love the 'prize' that is 'awarded' to gutless wonders in that site:
      "This product is the bomb!"
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        #843
        Considering the "special effects" that occur when one powers up a computer with one of these things, it is very adequate.
        • c_hegge
          • Sep 2009
          • 5219
          The funny part is that if you type "Produto Bomba" into google translate, you get "Product Pump"
          • TELVM
            • Oct 2012
            • 547
            • Spain
            #845
            ^ Yeah in portuguese and spanish the same word bomba is used both for bomb and pump.
            This leads to the funny situation where firemen are called bomberos ('bombers' ).
            • TELVM
              • Oct 2012
              • 547
              • Spain
              #846
              A fearsome squad of bomberas :
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                #847
                ... only if it's assembled by a group of terrorists.
                • rogfanther
                  • Jul 2006
                  • 458
                  • Brazil
                  #848
                  Also causes some problems in airport security, when people don´t know the correct name for something ( like asthma pumps ) and call it "bombs" ...
                  • TELVM
                    • Oct 2012
                    • 547
                    • Spain
                    #849
                    Another even worse 'TOOQ' gutless wonder :
                    Behold its mighty rectifier bridge :
                    (Should I 'upgrade' to a four-diode treatment?)
                    Somebody messed up and put 13009s instead of the traditional 13007s:
                    Armoured extra thick heatsinks:
                    Exquisite output filtering courtesy of state-of-the-art, stealth technology PI coils:
                    And not a single SATA connector !
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      #850
                      270w max
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Worldwide EA-300
                        Seen a Worldwide PSU before, but it was a rebranded CWT ISO series PSU. This ones UL number leads to "MITACHI TAIWAN CO LTD" and the fan pretty much confirms this. For the 300W label it looks alright.
                        First time I've ever seen Su'scon on the voltage doubler of a PSU, 560uF isn't bad. 4A bridge, switchers are your standard 12A 13009 transistors, and 2 transistor 5VSB. The input filter is decent minus the fact that those aren't safety approved Y caps and the spots for the MOV's were not filled.
                        35 transformer, decent sized 5VSB transformer.
                        Here's what I don't understand about this PSU. Where is the toroid for the 3.3V regulation, and the 3.3V output?! Also, instead of your average 16-20A ultra fast, there's a 40A MOSFET on the 3.3V rail. Why would they use this method? 16A ultra fast for 12V and 30A schottky for 5V. Both the 12V and 5V have room for another rectifier in parallel. All of the caps minus the bulk caps are JEE, and surprisingly only one of them on the 5VSB is bulging. Although I wouldn't be surprised if some of the other ones had high ESR. According to the PWM chip, this thing was manufactured sometime in late 2006.
                        Also really glad that this things fan doesn't run at 100% all the time!
                        • c_hegge
                          • Sep 2009
                          • 5219
                          The 3.3V rail uses linear DC-DC conversion from the 5V rail, which doesn't require a toroid coil. It's used because it's cheaper than using a separate rectification circuit for it.
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Cool, thanks! Does it yield any benefits such has higher efficiency, or does it just reduce the ripple on the 3.3V rail?
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              #854
                              It's just cheap. Linear regulation is the cleanest and simplest, but also the most inefficient form of regulation, as the difference between input voltage and output voltage is dropped across the regulator element and wasted as heat. Basically the regulating element behaves like an automated variable resistor.
                              A working TV? How boring!
                              • Behemot
                                • 4845
                                • CZ
                                #855
                                It's 34 watts at 20 A? OMG, what is efficiency of this thing, 40 %?
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  Interesting. Does this create more heat on the only toroid since it's generated from the 5V? So it probably doesn't even need a PI coil for that rail to stay low on ripple. Luckily the 3.3V rail isn't stressed much at all in modern systems. I have this thing powering a Pentium D (90nm powerhog) with DDR RAM and a GT220, surprisingly even with that Pentium D at full load the 12V rail is staying steady at 11.97V. The fan did kick up quite a bit, but still pretty quiet.
                                  Are you talking about the 3.3V rectifier?
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #857
                                    Whole supply, in worst case scenario it burns 34 watts just at +3,3 V, don't rather think how much it burns on other rails
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      Haha When it was running that Pentium D system it was pulling about 150W and the secondary heatsink + toroid were 35C, 36C respectively. Doesn't seem too bad. This thing did not take a 30A schottky rectifier on the 12V, even one with 100V reverse voltage. Can I put a 12A ultra fast in parallel with the original 16A ultra fast? They're both MOSPEC with the same exact specs except the peak amperage. If not, I think two 12A ultra fasts in parallel would be better than a single 16A especially for efficiency, and combined probably good for ~19A
                                        master hoarder
                                        • May 2008
                                        • 12170
                                        • Bulgaria
                                        #859
                                        Indeed.
                                        But if you don't have much of a load on the 3.3V rail (which most systems nowadays don't), then this is nothing to worry about. In fact, I prefer this linear regulation method as you have the choice to use any caps you want on the output of the 3.3V rail and also the 3.3V rail outputs very very clean power.
                                        As far as I know, only old video cards like the Radeon 9500/9700, and 9800 used the 3.3V rail more heavily (like 2 to 5 Amps).
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #860
                                          The questino is, are they both really the same except for peak current?
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
