Thread Tools |
#921 |
City & State: Toronto, Ontario
My Country: Canada
![]() So, I have had 3 devices fail from bad capacitors in 1 week. A netgear switch, an antec neo he430 psu (failing) and the obvious
Bestec 250-12z PSU - failed ; not starting pc came from a HP/compaq core2duo system. just wouldn't start one day. disaseembly shows bulging caps, totally not surprising. at least the 12z didn't fry the motherboard. The 12E version DID fry another system I used to have. Repaired that psu but this one; I'm just going to trash as time has gone by and there are much better psu's worth refurbishing than this one. |
#922 |
CapXon Be Gone
City & State: Idaho
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
![]() I wouldn't expect anything less from CrapXon. It should fire right back up after a recap, if not I'd check the primary IC. These PSU's are great after a recap. And, yours has the white glue instead of the dreaded brown conductive-over-time glue. Nice!
#923 |
City & State: CA.
My Country: USA.
Line Voltage: 120-125VAC 60Hz.
![]() ^ Those aren't CapXon, those are Teapo.
#924 |
CapXon Be Gone
City & State: Idaho
![]() Oh geez, they are!
#925 |
My Country: Australia
Line Voltage: 240V 50Hz
![]() That's a first. I've never seen Bestec use anything but Jamicon, CapXon or OST.
I love putting bad caps and flat batteries in fire and watching them explode!! No wonder it doesn't work! You installed the jumper wires backwards ![]() Main PC: Core i7 3770K 3.5GHz, Gigabyte GA-Z77M-D3H-MVP, 8GB Kingston HyperX DDR3 1600, 240GB Intel 335 Series SSD, 750GB WD HDD, Sony Optiarc DVD RW, Palit nVidia GTX660 Ti, CoolerMaster N200 Case, Delta DPS-600MB 600W PSU, Hauppauge TV Tuner, Windows 7 Home Premium Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro |
#926 |
CapXon Be Gone
City & State: Idaho
#927 |
CapXon Be Gone
City & State: Idaho
![]() Azza Dynamo 850W. Paid $20 for it, sweet deal! Obviously Super Flower made. It would boot up for about 3 seconds and then shut down. I figured, hey, those bulged caps might have something to do with it
![]() I recapped it, removed all the glue, fixed bad joints, oiled the fan, and it's good to go ![]() Look at those beefy CapXon! They measured 1200µF too, good job CapXon! They're heavy too. 15A bridge on a heatsink I was extremely surprised that the caps that went bad were on the 5V and 3.3V rail. ALL of the bulged JPCE-TUR 3300µF 10V caps measured in the range of 1500-1600µF and in the ESR range of 1.3-1.65Ω 12V uses 40A schottky's in parallel. |
#928 |
City & State: Prague, 50°4'52.22"N, 14°23'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
![]() Seems good for 550 W combined, with some luck 500 W on +12 V itself.
Less jewellery, more gold into electrotech industry! ![]() ![]() Exclusive caps, meters and more! Hardware Insights - power supply reviews and more!
#929 |
![]() SuperFlower were one of the few who could come up with a good half bridge design. That PSU would be a little inefficient, but it would have good output performance.
#930 |
City & State: Madrid
My Country: Spain
Line Voltage: 230V 50Hz
#931 |
Capaholic
City & State: Trenton, NJ
Line Voltage: 240/120V 60Hz
I'm a: Hardcore Geek
![]() Wooooooooow!!!! That's an awesome PSU.
Even the 5V_STBY transformer looks a little bigger than in some cheap PSUs. It also has a chip right next to it, so it likely isn't the killer two transistor design.
Muh-soggy-knee |
#932 |
City & State: Melbourne
Line Voltage: 230VAC 50Hz
![]() The last Bestec I scrapped had JPCE-TUR caps, although it was a 2000 model ATX-1523F powering a Socket A Duron rather than anything more recent. The mains caps were Taicon.
#933 |
My Country: CZ
![]() CEC International Holdings Ltd.
#934 |
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
![]() inland ils-600r2
where to start on this overated POS! appear to be fake nippon caps too. dented and appearance of dirt under the wrap.measures +- 700uf and 2.7 esr! secondary rectifiers are all 30a.claims 36a on +12. it was dead when it came in so no testing.but everything screams JUNK! inland is a micro center house brand. i suspect cougar is too. |
#935 |
My Country: U.S.A!
![]() more on the ils-600r2
FAKE caps |
#936 |
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
![]() 600W ... do you want shrapnel with that? No matter, you're going to GET it anyway!
So, wrong sleeve color, no temperature rating, and no date/lot code ... you got a problem with that?
PeteS in CA Power Supplies should be boring: No loud noises, no bright flashes, and no bad smells. **************************** To kill personal responsibility, initiative or success, punish it by taxing it. To encourage irresponsibility, improvidence, dependence and failure, reward it by subsidizing it. **************************** Anti-Covid-Vaxxer pig crap claim/prediction, Doctor: Heart Failure from mRNA Jabs "Will Kill Most People" | Principia Scientific Intl. ; Dr. Geert Vanden Bossche Warns COVID-19 Jab Injuries and Deaths Will Soon "Collapse Our Health System" (VIDEO) ; Fully Vaxxed May 2021; Since that time I've done 13 5Ks, 1 8K, 12 10Ks, and 4 half marathons Last edited by PeteS in CA; 01-18-2014 at 01:19 PM.. |
#937 |
My Country: CZ
![]() Fakes for sure, KMGs are brown and I think don't have that top cover. I have some KMQs and they don't have anything over the vent.
But the blue PCB is nice ![]() |
#938 |
I see dead caps
City & State: Hiding inside a plated-through hole
My Country: New Zealand
![]() Inland PSU?
Should be IN a LANDfill. Haha.
"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous" -David VanHorn |
#939 |
CapXon Be Gone
City & State: Idaho
![]() Definitely a Leadman. For 600W, it sucks but it's not even close to worst thing in this thread
#940 |
master hoarder
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Thread Tools | |
