Thread Tools |
#981 |
City & State: North Springfield, Vermont
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
![]() "WAM BOMD" LOL!
I guess the PSU gets bombed when turning it on! ![]()
ASRock B550 PG Velocita Ryzen 7 "Vermeer" 5800X 16 GB AData XPG Spectrix D41 Sapphire Nitro+ Radeon RX 6750 XT eVGA Supernova G3 750W Western Digital Black SN850 1TB NVMe SSD "ˇMe encanta "Me Encanta o Enlistarlo con Hilary Farr"!" -mí mismo "There's nothing more unattractive than a chick smoking a cigarette" -Topcat "Today's lesson in pissivity comes in the form of a ziplock baggie full of GPU extension brackets & hardware that for the last ~3 years have been on my bench, always in my way, getting moved around constantly....and yesterday I found myself in need of them....and the bastards are now nowhere to be found! Motherfracker!!" -Topcat "did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 |
#982 |
City & State: Windsor, Colorado
My Country: United States
I'm a: Hobbyist Tech
![]() Just Wireless 04111
I have posted about this charger before, but I know slightly more now. Also, I figured out how to take usable pictures with my horrible camera since then. It uses the two-transistor oscillator circuit with 13003 and C945 transistors. The secondary rectifier is a 1N5819, and the filter cap is 470µF 16V That seems acceptable for a simple 2.5W power supply. However, the primary and secondary ground are connected directly together. The output ground wire is connected directly to the negative lead of the primary filter cap. Only the bridge rectifier separates the output from the 120VAC input. That doesn't seem okay to me. Whether that is safe or not, this is a piece of junk. There is no feedback, and the output voltage drops significantly as the load increases. Yes, I actually plugged it in. ![]() The current sensing circuit used to light the yellow charging indicator LED just measures the voltage drop across a 1N400x diode that is connected in series with the output. This adds an extra voltage drop and an extra source of heat. This diode runs hotter than anything else in this piece of crap, and it seems to drop 0.8V instead of 0.6V like a normal diode should. |
#983 |
CapXon Be Gone
City & State: Idaho
Line Voltage: 120VAC 60Hz
![]() The fan failed on it, and so it overheated. It smells absolutely terrible, and so does the case even after replacing the PSU and dusting it. Surprisingly, all the hardware is okay. The Panny caps on the mobo could handle all the extra ripple
#984 |
My Country: Australia
Line Voltage: 240V 50Hz
![]() Looks pretty similar to this - http://hardwareinsights.com/wp/simba...supply-review/
I imagine the Day-1 performance would be similar too ![]()
I love putting bad caps and flat batteries in fire and watching them explode!! No wonder it doesn't work! You installed the jumper wires backwards ![]() Main PC: Core i7 3770K 3.5GHz, Gigabyte GA-Z77M-D3H-MVP, 8GB Kingston HyperX DDR3 1600, 240GB Intel 335 Series SSD, 750GB WD HDD, Sony Optiarc DVD RW, Palit nVidia GTX660 Ti, CoolerMaster N200 Case, Delta DPS-600MB 600W PSU, Hauppauge TV Tuner, Windows 7 Home Premium Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro |
#985 |
I see dead caps
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
![]() Probably the 'lead-free' version - Or pretending to be...? A lot of manufactures seem to use a Z suffix code for lead free.
"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous" -David VanHorn |
#986 |
City & State: Europe
![]() "Or pretending to be...?" ??
why pretend, lead costs more than tin. and tin costs more than nothing - there is a chinese source selling TI chips with bare pins. they are getting them after resin-stage and before the tinning - probably via the fire-exit! |
#987 |
City & State: Thessaloniki, Greece
My Country: Greece
![]() Hantol HPSU500
Yet, another terrible power supply. This time there is no fake PPFC because there is no PFC at all! The output torroid coil is used for 5V, 3V and 12V. I didn't take the photos. |
#988 | |
![]() Quote:
#989 |
![]() No pics, just my 2 cents.
When ordering a few computer items from cwc-group, and I noticed they had a 450w power supply for $15. Yeah I know. But I needed an extra for testing, and I was already paying shipping for the other items, so I thought why not. I hooked it up to a test board, shorted the power pins on the motherboard, and about two seconds later, POP! Ugh. I never tried fixing a power supply before, but with some experience recapping motherboards, I thought why not open it up and look. I know about the dangers of the two big caps, so I let it sit for a day. I checked those two with my multimeter and both read 0v. I also dragged a screwdriver shaft all over the solder side of the board to check for sparks. All quiet. Sure enough, I found one cap tilted, vented at the bottom. Must have been the POP I heard. It was a 16v 470uf. I had two in stock, so I heated up the iron and replaced it. Started over with test board ... two seconds ... no explosions ... two more seconds ... got video. Wheee! It's been running about 20 minutes now and I'm using it to post this message. The QC date code on the power supply was 2006, it sat in inventory for 8 years. I guess the exploded cap had trouble reforming? Before finding this web site and learning to replace caps, I never would have attempted anything like this. So thanks for all the info. But please, unless you are trained and/or know what you're doing, don't experiment with this idea! The big caps can be dangerous, even deadly. ![]() Last edited by a23d56; 06-12-2014 at 10:50 AM.. |
#990 | |
5000!
City & State: South Greeley, Wyoming
My Country: US
Line Voltage: 13.9kv HT service and some 240v center tap oddity.
![]() Quote:
Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo.... "Dude, this is Wyoming, i hopped on and sent 'er. No fucking around." -- Me Excuse me while i do something dangerous You must have a sad, sad boring life if you hate on people harmlessly enjoying life with an animal costume. Sometimes you need to break shit to fix it.... Thats why my lawnmower doesn't have a deadman switch or engine brake anymore ![]() Follow the white rabbit. |
#991 | |
![]() Quote:
#992 | |
My Country: Greece
![]() Quote:
#993 |
5000!
My Country: US
#994 | |
![]() Quote:
IIRC, the model was DR-300ATX or similar. Even when it was in better shape than the first Deer I had, I chucked it! I got the VPower on July 1, 2003, because it came with a case and I was losing trust in my PowMax LP-6100C, even when I just got it on July 5, 2002. Despite they appear to be a lot better than recent PowMax PSUs. I'm now glad that I got an Antec True 430, despite having Fuhjyyu caps, later in 2003, in October. Last edited by RJARRRPCGP; 06-15-2014 at 02:45 PM.. |
#995 |
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
![]() had an emacs itx unit i got new 5 years ago pop a cap.
it was run about 15 minutes for a test and stored. last week someone brought in a thoroughly roasted one.i new these had lousy caps so i figured i would recap it before modding it to run the tool grinder it was headed for. dammed if it didnt have a badly popped cap! now this did not happen while i ran the original test! i would have heard it. it either popped during the assembly line test or while it was sitting! |
#996 | |
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
![]() Quote:
PeteS in CA Power Supplies should be boring: No loud noises, no bright flashes, and no bad smells. **************************** To kill personal responsibility, initiative or success, punish it by taxing it. To encourage irresponsibility, improvidence, dependence and failure, reward it by subsidizing it. **************************** Anti-Covid-Vaxxer pig crap claim/prediction, Doctor: Heart Failure from mRNA Jabs "Will Kill Most People" | Principia Scientific Intl. ; Dr. Geert Vanden Bossche Warns COVID-19 Jab Injuries and Deaths Will Soon "Collapse Our Health System" (VIDEO) ; Fully Vaxxed May 2021; Since that time I've done 13 5Ks, 1 8K, 12 10Ks, and 4 half marathons |
#997 |
CapXon Be Gone
City & State: Idaho
![]() Oh boy, what a shame with this one. It had potential! Almost no input filter, those Y caps actually have safety markings on them though (I'm as surprised as you are!) 4A bridge, 560µF "ZHIFA" input caps, uses TO-247 13009's, and the heatsink is actually very strong. Transformer is okay size, but my main gripe is probably easy to guess...the output filtering! Where is it?
![]() ![]() Silly question: If I were to put a 16V cap in that second fan connector slot, would it filter noise since the fans are wired straight to 12v? ![]() Last edited by Pentium4; 08-14-2014 at 07:14 PM.. Reason: TYPO |
#998 |
City & State: Prague, 50°4'52.22"N, 14°23'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
![]() Yeah seems you are right but I would not put bigger cap than a 1000uF one in there, the paths are quite thin and with great capacity you will have quite big amount of power flowing here and there as the cap will charge and discharge.
I would add second ultrafast to the +12 V rail, it has position for two, than it should get better efficiency and some reasonable voltage under heavy load on this rail.
Less jewellery, more gold into electrotech industry! ![]() ![]() Exclusive caps, meters and more! Hardware Insights - power supply reviews and more!
#999 |
City & State: Tamaulipas
My Country: Mexico
Line Voltage: 115VAC 60Hz
![]() This is a classic LC with the "chip-of-the-year," yeah I know, there are enough LCs here but I feel the need to post it because this one came pre-installed in a NEW computer case (TrueBasix brand) so it SHOULD BE A NEW P/S right? ...maybe a crappy one, but NEW nonetheless, well...Not this time!
![]() It's not just old, it's used, awfully repaired, not even cleaned, corroded, and ALL caps have date codes from 2004. ![]() |
#1000 |
My Country: Greece
![]() This is their 2003 design! How did it end up being sold as a 2012/2013 product?
Thread Tools | |
