Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 12-05-2015, 06:23 AM   #1161
goodpsusearch
City & State: Thessaloniki, Greece
My Country: Greece
Line Voltage: 230VAC 50Hz
Default Re: the gutless, bloated, and fried power supply hall of shame
goodpsusearch is offline   Reply With Quote
Old 12-05-2015, 02:33 PM   #1162
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
I'm a: Hobbyist Tech
Maybe it's for the 5vSB rail? That might get away without a heatsink.
-David VanHorn
Agent24 is offline   Reply With Quote
Old 12-06-2015, 05:44 AM   #1163
Behemot
Behemot's Avatar
City & State: Prague, 504'52.22"N, 1423'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
OFC it is SB rail…there is no booster so the switchers will be far on left.
This is absolutelly normal.
Behemot is offline   Reply With Quote
Old 12-06-2015, 02:58 PM   #1164
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Originally Posted by Pentium4 View Post
Shame on you, Solytech...
This thing managed to power a computer for 2 years and never failed. Pretty surprising!
http://www.badcaps.net/forum/attachm...1&d=1449294660
Haha! At first, I didn't even notice anything wrong there. It wasn't until I read all of the replies after this that I realized what was wrong.
Wow, that is... shocking? ...or amazing?
Even though this IS for the 5VSB rail, I am surprised that it didn't fail within minutes. The older Deer/Allied/L&C PSUs tend to generate a lot of heat in soft-OFF/standby mode. I guess Solytech must have improved their 5VSB designs a little. My Deer DR-250ATX keeps the whole primary heatsink nice and warm (about 40-50C) in soft-OFF mode. So I would guess that transistor is dissipating no less than 1 Watt. If this was the case here with this PSU, the PCB underneath that transistor would definitely have become crispy, especially around the Collector pin. Then again, it's hard to tell with a PCB painted black.
momaka is online now   Reply With Quote
Old 12-06-2015, 03:19 PM   #1165
Behemot
Behemot's Avatar
My Country: CZ
Possibly there is already some PWM driver, if the unit is only few years old. EU regulations in this area already work for some time…and manufacturers tend to have single paltform for all markets.
Old 12-07-2015, 06:59 PM   #1166
ben7
Capaholic
ben7's Avatar
City & State: Trenton, NJ
Line Voltage: 240/120V 60Hz
I'm a: Hardcore Geek
Dell H240AS-00
I posted pics of this PSU before, and I seem to recall someone saying to replace a ceramic cap, but I looked and couldn't find that post.
Well .... you were right. I think it finally failed.
That computer was brought back to me, and had no power. No 5v stby
The picture tells it all! :P
She blowed up real good!
Notice the soot around the fuse! Holy moses! Somethin done gone bang for sure!
.. Looks like I have a power supply to fix
-Ben
Muh-soggy-knee
ben7 is offline   Reply With Quote
Old 12-07-2015, 07:14 PM   #1167
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
Looks like that ceramic cap is across Drain and Source on the FET behind it. Also note the small hole in the resistor too! Judging by the resistance value of that resistor, it is probably used as a Source resistor for the FET - and if it is, you might want to check the FET too. I see a 420V primary cap behind. APFC PSU? If yes, I bet that's all that is wrong with it.
Mmm-hmmm
Old 12-07-2015, 07:22 PM   #1168
ben7
Capaholic
ben7's Avatar
Yes I am just about the check the FET and other primary side power devices.
And yes it has APFC! Somewhat surprising for a 240W PSU.
-Ben
Old 12-07-2015, 07:42 PM   #1169
ben7
Capaholic
ben7's Avatar
[Quick update]
(Will make new thread if I need to, but I don't at the moment. Don't want to hijack lol)
The main switching FET is shorted, the APFC FET is shorted, and the APFC diode seems unhealthy. (Measures 200 ohms both ways, and this is in circuit.)
The APFC FET shorted badly, I get 0.4 ohms on the + and - of the bridge rectifier. (All 4 bridge rect diodes test fine though, forward voltage wise.)
It's REALLY gone pop!...
No wonder why the fuse blew so hard!
An SMD diode and resistor have blown as well.
Edit: Holy crap! Gee, a switching controller chip on a daughterboard is burnt as well!...
-Ben
Old 12-07-2015, 08:00 PM   #1170
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
As PhotonicInduction would say:
Awwwww. We POPed it!
I'd still try to repair it, though, just for fun. If you do that, then yeah, make a thread for it (and with more pictures of the carnage!)
Old 12-08-2015, 01:33 PM   #1171
Agent24
I see dead caps
Agent24's Avatar
I guess the ceramic capacitor shorted out (maybe voltage rating too low/bad quality?) and caused everything else to fail.
I can't imagine how the capacitor would fail if the FET blew first.
Old 12-13-2015, 04:41 AM   #1172
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Well Ben, I sent you this PM on November 28, how is that memory going? :P
Originally Posted by Per Hansson
Hi, re your Dell PSU here: http://www.badcaps.net/forum/showpos...postcount=2314
Do read this thread, might be a good idea to replace that ceramic cap before it fails!
http://www.badcaps.net/forum/showthread.php?t=40726
Ah, well, I don't have that supply any more.... :/
-Ben
EDIT: Saw your new thread now, here is is for others that want to follow
http://www.badcaps.net/forum/showthread.php?t=50864
Old 12-13-2015, 09:07 AM   #1173
ben7
Capaholic
ben7's Avatar
*Atomic Facepalm*
No wonder why I couldn't find it ... it wasn't a post, it was a PM!
Gosh, I'm getting old!
My brain belongs in this hall of shame.
-Ben
Old 12-14-2015, 08:35 PM   #1174
coreAngel
coreAngel's Avatar
City & State: FL
My Country: United States
Line Voltage: 120 VAC 60Hz
Hello everyone i haven't posted in a while and i thought now is the best time to do so.
So i purchased today a slim ITX case with an HEC psu (that i found at a local retailer of electronics which is closing it's last remaining store permanently , in FL) i saw it was in excellent condition but they were asking several months ago 75 dollars for it, i waited until today which the price was reduced to 15 dollars for everything and the case includes a 8x slim DVD combo drive.
Well now that the story is out of the way i was thinking is the HEC psu worth it as it's maximum power output is 200 watts.Active PFC (as the area where the voltage selector switch is covered with a sticker) It has 14 amps in the 12+ side. It has a bridge rectifier, 8 amp not heatsinked, Primary capxon(or should i say Crapxon, but it's the primary) cap all other caps are teapo with exception of some sus'con caps on some daughterboards which are tiny caps. Should i toss it? can i actually use this PSU or switch to another brand?
thanks
Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboard
coreAngel is offline   Reply With Quote
Old 12-14-2015, 08:47 PM   #1175
coreAngel
coreAngel's Avatar
City & State: FL
This one really surprised me this is a notebook power brick which i bought off ebay for a bit less than an original hp adapter. The components are not all secured, questionable caps, the components which are crucial can only output 12 volts not the 19 v needed to work properly no wonder the brick got so hot i became worried and unplugged it.
Qinfen primary cap, and oxxa caps on the rest... yes they are using the logo from oxxo good grips kitchen utensils to put oxxa for some type of fake cap....
My laser thermometer read the case of the power brick under moderate use at almost 88 C either somethings wrong with it or it must be the worst design ever...
This really belongs as crap
And yes i bought a genuine HP power adaptor after this
Old 12-15-2015, 04:09 AM   #1176
Behemot
Behemot's Avatar
My Country: CZ
The pic of that HEC unit are terrible man.
Well, some of the chinese bricks are somewhat decent, just with cheap caps. But this is terrible. Primary and secondary connected by common heatsink? OMG! And that primary switcher is not even screwed to it, it is flying apart!
Old 12-15-2015, 05:11 AM   #1177
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Should the HP f1905 PSU be a candidate for this list?
After some time with no signal (but the power light was on), it would display black with a snowy white border (but was OK when a signal source was applied) - when I opened it up, I found that the 450V 150uF Elite PW Series unit was leaking at one of its pins.
Most of the other electrolytics were Elite EL, with two unknown brand units, and near each of the two backlight inverters was one Chemi-Con KY unit.
japlytic is offline   Reply With Quote
Old 12-15-2015, 05:33 AM   #1178
Behemot
Behemot's Avatar
My Country: CZ
Elite, that's quite common. It can go as far as the electrode completelly rotting off.
Old 12-15-2015, 07:42 AM   #1179
coreAngel
coreAngel's Avatar
City & State: FL
I will try to take pics of the HEC again so it's more clear but it's a really tight space so i don't know if it will all come out
Old 12-15-2015, 08:00 AM   #1180
ben7
Capaholic
ben7's Avatar
So i purchased today a slim ITX case with an HEC psu ... *snip* ... Should i toss it? can i actually use this PSU or switch to another brand?
thanks
It looks good to me. I dunno if it can do 200W, but the quality looks good from what I can tell. Except for the cheap caps of course.
It's hard to tell how well it might work. Just because the heatsinks may be smaller than usual, doesn't mean that the power supply is improperly designed. If efficient enough, it doesn't need huge heatsinks.
Doesn't surprise me! :P
You might be able to modify the feedback so that the output voltage is correct, at 19V.
Also, the cable going to the laptop itself might be poor quality - as in, too fine of a gauge of wire - there might be voltage drop there as well. But a 7V drop seems a bit too much even with fine wire ... it might be the power supply itself that is set for 12V out.
In regards to the extreme heating ... It might be a poor design, or maybe they might have picked cheap parts for the switching transistor and the output rectifier. Also I know those transformers can run quite hot too. Perhaps the switching frequency isn't optimal, so the losses are higher ... who knows
(( Could you read us the part numbers for the switching transistor and the output rectifier? ))
But ... 88C on the outside case is not acceptable! You might not be able to boil water on it under regular conditions, but you still could get a slight burn from it! Wow!
Also note how the heatsink is extruded! Interesting, they went to the effort to do that instead of doing what is usually done, using a [folded] bar of metal (This is done in the genuine PSUs as well, so it's not exactly poor practice)
-Ben
Badcaps.net Technical Forums 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
