hp 15s-fq0017na Caps lock blinking 3 slow, 2 fast
    No voltage on R15 coil.
    All other coils have voltage.
    No display.
    I have cleaned and reseated the single ram module.Problem persists.
    Any ideas on this issue.
    Hp site suggests memory issue but I have tried working ram still the same.
    PLs help.
    Re: hp 15s-fq0017na Caps lock blinking 3 slow, 2 fast
    First write down board number so we can find out what is R15 coil used for.
    Check for shorts on that coil, and measure if there are any brief pulses of voltage during startup on that coil.
    If no shorts on that rail, I would suggest backing up bios and reprogramming it with clean ME file, also, if the EC is programmable, backup and reprogram it.
    I don't provide help for people using CH341A and a clip.
      da00p5MB6D0 REV D
      ALL of the following shows beeps on both sides to ground in continuity mode.
      In resistance mode to ground both sides of coil show the following.
      R24=12 OHMS
      1R5=23 OHMS
      4R7=00 OHMS
      2R2=21 OHMS
      R15=18 OHMS
      NO brief pulses of voltage on standby on R15
        Almost every cap in the vicinity shows short to ground!
          As far as I can tell, there is no schematic or boardview available for this board. At least post high quality pictures of the board, maybe someone would be able to help.
            hI,
            here are some photos.Could this problem be caused by the CPU?
              Originally posted by vikivng View Post
              da00p5MB6D0 REV D
              R24=12 OHMS
              1R5=23 OHMS
              4R7=00 OHMS
              2R2=21 OHMS
              R15=18 OHMS
              1R5 or 4R7-these are ratings for coil/resistor. Does it makes any sense to us. How do i know the coil 1R5 stands for which rail?? Resistance between different coils may vary like hell & heaven,eg, resistance on vcore rail may be 5 Ohms whereas the same rating on ram coil is definitely showing short. So we cant make out anything about ur resistance readings unless u mention the coils are meant for which rail. So please do the home work properly and we'll try to help you as far as possible.
                Hello
                Did this get sorted in the end?
                I have the same board with the same problem...
                  Originally posted by Benjammo View Post
                  Hello
                  Do not know the solution but the caps lock blink sequence relates to memory and BIOS:
                  The embedded controller times out waiting for BIOS to return from memory initialization.
                  I'm fairly new here too but maybe better to open a new topic with more details on the problem (maybe same symphton but your board readings could differ and point to a different source of the problem).
                  Here some Beginner's guidelines to get started.
                    Try to reset emmbedded controller. Check bios image if it is corrupted. Try boot with ram replaced. Try run recovery bios with WIN+B and recovery flash. Possibly embedded controller firmware falure
                      is this problem solved? i have a HP laptop and it has the same problem. reflashing BIOS solves its problem but black screen and blinking caps lock returns. i always reflash bios, and it always solves the problem but the problem always comes back.
                        Hi if you flash bios dobyou flash clean me region bios.
