Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 05-30-2021, 10:21 PM   #61
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Default Re: Compaq PDP-121P - Baked MOV
Originally Posted by socketa View Post
It's a long shot, but could broken stands that were going to the coil result in the power supply not getting, (and maintaining under load) enough voltage? Hence the computer shutting it down.
Probably not.
The DC voltages on your input caps looked good and didn't seem to drop out / dip when turning On the PSU... so I suspect this isn't the issue.
Nonetheless, it does need to be addressed just in case. Just because I don't *think* it is a *likely* issue doesn't mean that it can't be one.
Can i cut the yellow plastic tape, and reattach the wire to the coil? (hopefully there is no windings inside of it)
Yes.
Though there should be windings inside. This is the PPFC inductor, after all.
Would it be OK to remove it (i'm guessing that it's passive PFC) and replace it with a jumper?
Yes.
Originally Posted by sam_sam_sam View Post
yes but the values less 1k ohm are an issue
Why would that be an issue?
I've seen a lot of PSUs with low-value load resistors... hence measuring much lower resistance on the 12V rail. So I don't really think the resistance alone can tell you anything.
Your reading should be very close or the same as the good one if both switching power supply are exactly the same model number and have the same exact ic chip on both boards
^ This.
If the PSUs were the same, I'd definitely try to see why there was such a wild mismatch between the resistances. But...
The power supplies are not the same
That pretty much invalidates the resistance comparison... or at least as far as showing any information that may suggest a problem.
i know that PSUs can have quite different values for minimum load resistors.
Exactly!
I suppose no harm in posting the resistances. Though when things measure above a few hundred Ohms on the output, then generally that means at least there is nothing wrong with the big power delivery components (i.e. rectifiers or their snubbers being shorted.) But it doesn't really amount to much of anything else. Open feedback resistors can essentially go completely unnoticed, due to their relatively high resistance value. So a resistance check on the voltage rail won't tell you if one went bad or not. This can only be found through careful component testing and perhaps a schematic or application diagram of the supervisor chip to understand what is going on.
That being said... and recently trying out an experiment with a non-working PSU that helped me find the problem... maybe this troubleshooting trick could work here too:
- Take a working ATX PSU and backfeed each rail into the non-working PSU, one at a time only, then power-up the non-working PSU too and see if it stays turned On.
So for example, let's start with the 3.3V rail: connect the 3.3V of both PSUs together and turn On the working PSU. Verify that 3.3V is back-feeding into the non-working PSU. Then turn On the non-working PSU with a load and see if it can stay turned On without shutting down. If not, repeat this experiment for the 5V rail (after disconnecting the 3.3V rail.) Then do the 12V rail and -12V rail. Since the 5VSB is derived from a different circuit, don't do this experiment for the 5VSB. Also don't connect any of the signal lines on the two PSUs, such as PS-ON or PG. However, for the specific test of the 3.3V rail, make sure the 3.3V "return" / "sense" (if there is one) is connected on both PSUs. Without 3.3V sense, 3.3V rail could be off-value on one or both PSUs.
If you do find that the non-working PSU stays turned On when one of these rails is connected, then there may be something wrong with the output of that rail on the PSU.
The only tricky part with the PSU from this thread is that it has a 12.8V rail... so not sure if we should be back-feeding this one or just the regular 12V rail. But I suppose you could try both. Nothing should really smoke or burn, so long as both PSUs are decent brands (i.e. have good working protections.) I would avoid using a "cheapie" gutless wonder for this test.
Old 05-31-2021, 01:50 AM   #62
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Can you please show a hook up diagram for how you hook up the two power supply board and give more details about how to do this test correctly
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 06-01-2021, 09:06 PM   #63
socketa
Asbelowsoabove
socketa's Avatar
City & State: hell
My Country: samsara
Line Voltage: 230v
I replaced the coil with a jumper - but no change, as expected
So then i back-fed the 5V, and no change
Then I back-fed only the 12V, and the computer started
That was a nice surprise
With the computer running, I checked the back-fed 12V rail, and it's the same as the 12.8V CPU rail, at 11.65V
Could it be mere coincidence that both rails are the same voltage?
(Wasn't exactly sure about what you meant by connecting the 3.3V sense wire on both PSUs - did you mean that sometimes the manufacturers don't bother connecting the sense wire on some power supplies?)
So it looks like there is an issue with the 12V rail?
Perhaps something 'funny' going on between the 12V and the 12.8V rails?
socketa is offline   Reply With Quote
Old 06-02-2021, 02:51 AM   #64
socketa
Asbelowsoabove
socketa's Avatar
City & State: hell
My Country: samsara
Line Voltage: 230v
...and perhaps it's useful to note that the resistance between the 12V, and the 12.8V, rails is 12.8kohms
Old 06-10-2021, 12:21 AM   #65
socketa
Asbelowsoabove
socketa's Avatar
City & State: hell
My Country: samsara
Line Voltage: 230v
I've traced out some of the circuitry and identified the components
The MOSFET isn't shorted, but maybe it's still faulty?
Could whatever it was that blew the primary side components also have damaged this secondary side MOSFET?
Just because i could, i removed the 4 pin CPU plug from the motherboard and powered it from another PSU, but it didn't make any difference.
So i get the impression that the problem is with the 12V rail, not the 12.8V rail
Old 06-13-2021, 06:54 PM   #66
socketa
Asbelowsoabove
socketa's Avatar
City & State: hell
My Country: samsara
Line Voltage: 230v
I tested the STP40NF03L MOSFET with the transistor tester, and it identifies it as an "N-E-MOS"
with addional information:
vt = 1.8V
Cg = 2.2nf
RDS = 0.2ohms
Uf = 632 mV +
Does that look OK?
Old 06-16-2021, 09:22 PM   #67
socketa
Asbelowsoabove
socketa's Avatar
City & State: hell
My Country: samsara
Line Voltage: 230v
with the theory that there is a problem with the 12V rail (that appears to be derived from 12.8V rail) ...
would it be OK (i.e. not cause any damage) to disconnect the MOSFET and then try and start it up, to see if 12.8V comes up?
Old 06-16-2021, 11:30 PM   #68
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
vt = 1.8V
Cg = 2.2nf
RDS = 0.2ohms
Uf = 632 mV +
Does that look OK?
Yes, looks pretty normal. If the TT tester was able to identify it, then that means the MOSFET is actually working.
Looks like the MOSFET between the 12.8V and 12V rail is used either as a linear regulator or just a simple pass-through device. Check your schematic, though - I don't think that circuit can work just like that, with the Gate only connected to the Source pin via a cap. There has to be something more. In fact, if that MOSFET really is to operate as a pass-through device (or a linear regulator for that matter), then the Gate must always be higher than the Source by at least as much as the Gate threshold voltage, V_th. And for that to happen, then the Gate has to be pulled up by an external voltage source that is higher than 12V.
Yes, you can try that test. The 12V rail will just not appear. That being said, I suspect the PSU will not start at all with the 12V rail missing (when you remove that MOSFET), as it probably is monitoring it, along with the 12.8V rail.
So when you had the PSU power up OK with the other (working) PSU feeding into it, did you have that PSU's 12V rail connected to this PSU's 12.8V rail or just the 12V rail?
Old 06-16-2021, 11:48 PM   #69
socketa
Asbelowsoabove
socketa's Avatar
City & State: hell
My Country: samsara
Line Voltage: 230v
- yep, thanks for pointing that out (makes sense, and i should have recognized that there was nothing, on my drawing, to turn the MOSFET on).
i missed a thin trace that was going from the Gate, to a 100ohm resistor, and then to pin 3 (cathode) of a KA431AZ Programmable shunt regulator, that's located on the add-on board - i'll update my drawing later
And i'll check the voltage at the cathode of this programmable shunt regulator.
Just the 12V rail
Old 06-17-2021, 04:10 PM   #70
socketa
Asbelowsoabove
socketa's Avatar
City & State: hell
My Country: samsara
Line Voltage: 230v
I soldered the 12V rail MOSFET back onto the PCB and connected an analogue meter to it's gate terminal.
Then i plugged the rail cables into the motherboard and put the power cord into the wall socket
(i'm pretty sure that these Compaq computers start up straight away by themselves)
Then the voltage quickly rises to 5.5V and quickly drops to 3.5V, and stays there until i pull the wall plug out, and it quickly drops backs to zero after about 8 seconds (probably after the primarys discharge)
Pretty much the same result if i connect it to the other side of the 100ohm resistor
Old 06-17-2021, 07:16 PM   #71
socketa
Asbelowsoabove
socketa's Avatar
City & State: hell
My Country: samsara
Line Voltage: 230v
Made an error on the schematic
Here is the correct version
After connecting the rail cables to ATX, CPU, and hard drive, and then plugging in at the wall:
Attaching a meter to the gate of the 12V MOSFET
There is initially no voltage
After a couple of seconds (i guess after the primary's charge up and the computer automatically turns on) the PSU fan clicks, and the gate voltage rises to 5.5V, and settles at 3.5V
If i, instead, attach a meter to where it says on my schematic "large toroid and heatsink-mounted component", the voltage rises to 4V and drops to 0V
So can we say for sure that there is some problem with the creation of gate voltage?
Badcaps.net Technical Forums 2003 - 2021
