Repairing cables - ferrite bead and strain relievers
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    Does anyone know how best to re-adhere ferrite beads and strain relievers to cables, like when repairing a games console controller that has had wires broken near where the cable emerges from the controller?
    I found that the bead and reliever need to have a twist drill passed through to allow a fresh part of the cable to go through when the bad portion of cable was cut away. The material that came out was hard like the plastic cable cover, not like a silicone based material I half expected.
    Does anyone know how it's done at the factory?
  • llonen
    • Sep 2014
    • 495
    • hampshire
    Re: Repairing cables - ferrite bead and strain relievers
    Depends upon the strain relief, some of those are moulded to the cable itself, others are fed through and secured inside the unit. If its something that is likely to get some abuse then when I have these in for repair and mod will run a bead of silicon inside the strain relief. I get a lot of hoist controllers come through for rework from nursing and residential homes along with call bell systems. Call bell pendants I fill the 3/14" jack with either hot melt or silicone which works well enough.
    • Unspun01
      • Jun 2011
      • 333
      Internal wires are manufactured first. Then the internal wires are pulled through a jig that determines their orientation or lay. The foil shielding is applied over the wires at the same time. Then flexible protective cover over top.
      Once cables are cut to pre-determined lengths, they may have ferrite beads placed over the cable prior to having connectors or terminations soldered or crimped onto the ends of the wires.
      With cables now pre-manufactured, the cables are held in place in a mold where pressure injection of "stress relief material" is applied over the cover of the cable. You may notice that the cable material, and the injection molded material of the strain relief area are two different types of material. One melts much easier than the other, but they bond well together so they don't slip out.
      Using a drill bit of appropriate diameter is very useful to "drill out" the conductor covering material from the stress-relief cone if you intend to re-use the stress relief cone.
      Sometimes acetate glue (like crazy glue, etc) can be used, but is non-flexible. If it cracks, it may de-adhere from the cable and no longer provide the support you need.
      I prefer to use a small dab of RTV silicone on the internal area where the cable and the stress cone meet to prevent it from pulling out under normal use. Once the RTV solicone cures, it is slightly pliable, and so long as it adheres to the cable cover inside the controller, the cable will not be allowed to pull out from the stress cone.
      If you have sufficient cable length, you may also tie a knot in the cable inside the controller. This will absolutely prevent cable from pulling out (and no adhesives needed) but generally, there is little room to accommodate a know, and not usually good for the wires.
      On one repair, after I pulled the cable through the stress relief cone, I inserted a toothpick between the wires (inside the cable cover) and this increased the effective diameter of the cable so it would not pull out from the stress relief cone.
      Another time, I applied several wraps of vinyl electrical tape on the cable jacket adjacent to stress relief cone (inside controller). It worked for years until I sold it. But I was never rough with my stuff so while it worked for me, it may not work for everyone.
      One other helpful bit of advice I can offer, is that sometimes it is tough to get the cable jacket to slide back through the stress relief cone upon re-assembly. Do not use oil because the cable will slip back out and defeat any use of adhesives. Instead, use a drop of Palmolive or other dish soap. This will reduce friction, and is easily wiped or washed away, and permits use of silicone or other adhesive.
      • valvashon
        Repair Success! Middle Atlantic UPS2200R-IP
        by valvashon
        Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
        Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
        02-06-2024, 12:54 PM
      • H H
        3090 FE Part Confirm/Identification
        by H H
        I'm hoping someone could help me confirm if I have identified the following parts correctly.
        Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
        The parts needing replacement are on the back of the board behind the HDMI input.
        I have identified the parts as the following:
        C6037: MLCC 0.1uf/16v(0402)x7R W05
        R6016: RES 499 OHM 1/16W (0402) 1%
        LB10911: Ferrite Bead (0402)...
        02-16-2025, 01:09 PM
      • Borges
        Burned ferrite bead RTX 2080 LB617
        by Borges
        have purchased an RTX 2080 which contains a scorched component. I have carefully removed it with a heat station. The card is not short and it works, but it is seen with artifacts.
        The problem is that I cannot find the characteristics of the component anywhere. I am going to attach a photo in case someone has the same graphics card and can measure the component or if someone knows which one I have to buy. I would really appreciate it
        :trashcan:...
        12-14-2021, 03:20 PM
      • philtvman
        Turtle Beach 420X Blown Ferrite Bead
        by philtvman
        Working on this pair of headphones that will not stay powered on.
        A ferrite bead inside looks like it's fried and will need to be replaced (who knows if that's all that's bad). My question is, is there any safe assumption for a replacement? I don't think there are schematics for the board anywhere online unfortunately, so I have no idea the exact specs of it.
        Any advice would be much appreciated....
        01-22-2020, 12:31 PM
      • mrkmpn
        Need help replacing blown ferrite inductor (I think)
        by mrkmpn
        After installing a replacement screen, the backlighting went out and I discovered what I initially thought was a blown fuse. I reconnected the cracked screen and bridged the "fuse" with tweezers and the backlight came on, so I tried the same thing with the replacement screen and the tweezers just sparked, no backlight came on, and the "fuse" was damaged even more. (And yes, the screens were the same model number. I have received an RMA for the screen already)
        The reason I think it was a ferrite inductor is that 1st, it didn't look like a fuse I'd seen before,...
        06-07-2022, 03:52 PM
