Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting & Designing Networks
Old 02-21-2020, 02:32 PM   #1
nosugartonight
City & State: Bluefield Virginia
My Country: united states
Default Wifi signal
Hay. Not sure if This post is in the right place but here it is. My neighbor said I can use his wifi. The signal is weak. I assume it's because of the distance. Approximately 150 feet. Also there are other open wifi but are weak also. Is it possible to extend the antenna wire out of the tv to the outside to a antenna to improve signal strength.
nosugartonight is offline   Reply With Quote
Old 02-21-2020, 03:00 PM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Default Re: Wifi signal
get yourself a ubiquiti oudoor AP or similar.
Old 02-21-2020, 04:34 PM   #3
nosugartonight
Not looking for gadgets was just wanting to know if its possible. All smart TVs I've been into. Only have a small piece of metal at the end of antenna wire. So could that wire be extended to the outside, maybe connected to an Ariel antenna or simply to so aluminum foil to pick up better. any thoughts will be appreciated.
Old 02-21-2020, 06:15 PM   #4
stj
stj's Avatar
City & State: Europe
no, the losses in the cable will remove anything you gain from a decent 8dB+ antenna
Old 02-21-2020, 06:35 PM   #5
petehall347
City & State: worcester
My Country: United Kingdom
antennas on the router might help
Old 02-21-2020, 07:36 PM   #6
nosugartonight
Ok. I have routers .Not on his network.
Old 02-22-2020, 07:28 AM   #7
stj
stj's Avatar
maybe you can use a router in reverse to link to his router.
some have that option, others can sometimes have better software installed.
what routers do you have?
Old 03-29-2020, 02:19 PM   #8
madan1
City & State: Sofia
My Country: Bulgaria
Get a cheap tp-link 740, install dd-wrt and connect it to the other wifi network as a client. After that you can use cable to connect your TV ( and other devices ) to that router or add a virtual wireless network to which to connect your devices.
madan1 is offline   Reply With Quote
Old 04-11-2020, 12:16 PM   #9
Curious.George
+42
Relocate the router closest to the neighbor's house. Add a "cantenna" pointed directly at his source. Use CAT5 to make up the distance to the router's previous location. (note "router" can also be a laptop, etc. acting as a bridge)
If neighbor really wants to cooperate, he can add a cantenna on his end pointed back to yours.
If you can't get close to a mile with such an arrangement, you're not trying hard enough!
Curious.George is offline   Reply With Quote
Old 04-12-2020, 11:48 PM   #10
televizora
ghettomodmaster
City & State: Bulgaria
Line Voltage: 230VAC 50Hz
I'm a: Student Tech
This is neither smart, nor reliable. If you have money for smart TV, at least buy a cheap router with AP client function, waterproof junction box and put the router on your chimney and then connect it to the TV at your home. Second hand 5210G or M2 costs about 30$. Don't you have 30$ to save from cigarettes and whiskey? Even I have 3 AP's in storage - 2 TPLinks and one Bullet M2. Don't do stupid things if you don't want to be constantly frustrated with dropping connection. I used 5210G to connect to Repotec router on a 1.5km distance without issues. At least 15Mbps at any time.
Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
televizora is offline   Reply With Quote
Old 05-21-2020, 09:01 PM   #11
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
I send you PM message
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is online now   Reply With Quote
Old 06-01-2020, 12:27 AM   #12
simitaktas
City & State: geneva
My Country: switzerland
If youre not looking for a gadget, your best bet is to get your neighbor to reposition his/her router to accomodate you
simitaktas is offline   Reply With Quote
Old 06-05-2020, 01:36 AM   #13
simitaktas
I did more research and found a list of practical solutions that may be of help of to boost wifi signal
Old 06-05-2020, 10:28 AM   #14
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
This was the setup I had when using someone else's wireless network, a D-link AP with detachable antenna arrangement and a small 2.4ghz dish. The AP once configured was sealed up in a box and stuck up the pole with dish, power over Ethernet completed the arrangements. This setup worked flawlessly for a few years until they rolled out ADSL thus rendering the setup redundant.
llonen is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2021
