TV not powering on - with standby red –led flashing
    Re: TV not powering on - with standby red –led flashing
    Test c18-19 and 20 as described in post #55.
      They all start from sbout from 2.9ohm and rise then until the meter shows a 1 or l
        And the other non-suspect caps do the same when tested? The rise should be even and steady.
          It can be tricky tracking down bad caps, it doesn't take much being out of specs to cause a problem, here's NorCal tracking some down:
          https://www.youtube.com/watch?v=3S-3J-FySzc
            Found C16 to be doing nothing
            Edit... I set the meter to 2000k and then it show a steady increase,, so all the caps are good
              Well that's just a "dirty test", like I said a partial test you can try when you don't have the meters needed, to test them completely you need a meter or meters that can test capacitance and esr, the 10-20 dollar combo meters, there's a bunch on ebay, seem to be pretty accurate.
                Ok so a recap on the existing issue:
                power cord plugged in for ever the standby led give a solid status - the tv switch on.
                Power cord unplugged for 40sec, plug it back in flashing led status - does not switch on only if I heatup C18, C19, C20 led status change to solid and it powers on.
                Have replaced all caps, done the 'dirty cap test' as per nomoresonys suggested, as I have not an ESR meter think the caps must be all good as they are new..
                Ai seems as IF I need to throw in the towel but dont want to
                  On L1 it fluctuates 3.6 - 4.7 with the standby led flashing
                  When I unplug the CON3 plug for 10 sec plug it back the led stops flashing amd turn solid, then the volt on L1 is about 22v
                  D9 cathode voltage fluctuates from 21v - 60v that is without any pins jumped
                  D9 cathode is connected to L1 so the voltages should be the same.
                  I think that there is still aproblem with the standby circuit centered around U1 and Q4
                  Did you check D10 out of circuit.
                  R30 is 100 ohm and can you confirm that.
                  What value zener did you use to replace ZD3 which your schematic says is 18V
                    D9 to L1 - voltages are the same
                    R30-yes that is at 100ohm
                    Zener diode as in pic... Replaced it with a 18v one
                    D10 - help on this one, how do I measure {same as for any other diode} if so with the probes on the one way and then swapped the other way it does not matter what side I get one reading both ways 098 on multimeter
                      is d10 removed from the circuit it should only measure in one direction
                        In an earlier post this is what you gave
                        There is no reading for the 3.3v
                        C1 and C2 reads 315v for pinned and not pinned
                        Ohm readings for
                        ZD3... 00.4ohm
                        D10..25ohm
                        R26..00.5ohm
                        R28..510ohm(meter set to 2000ohm)
                        R29..18.7ohm
                        R30..25.1ohm
                        R31..00.7ohm
                        D10 is across 100 ohm resistor so should have read 100 ohms.
                        The only way to check is to lift D10 and put your meter in diode mode. You should have a reading one way eg 0.75 and no reading when you swap your meter leads over.
                        Then you can check that R30 does read 100 ohms
                          Agh sorry D10 is still in circuite,, will remove and give feedback again
                            D10 is lifted it gives me a reading only in one way on the diode test
                            When testing for resistance it gives 2.69ohms only in one direction
                            R30 gives me 98.6ohm
                              2.69 ohms or 2.69 Kohms or 2.69 Mohms?
                                The multimeter is set like in the non illuminated display, sorry but I got another meter and is not confident in using it and feel silly
                                Added the wrong image before this is now correct
                                  it's 2.69 Mohms, the range indicater is at the bottom MΩ
                                    Do I have to replace it, if so can I use the one as per attatchment
                                      If it's still out of circuit, check it in diode mode.
                                        It give a reading only in one direction
                                          That's what you want from a good diode.
