Samsung 32 Inch power supply problem BN44-0260A
    Hi
    This set uses the BN44-0260A Power supply
    It came in with IC UM8015 (ICE3BR0665) Blown
    Replaced IC but now I have a stable 13 Volt but the 5volt rail is pulsing around 2.5 volts. Checked diodes and caps but getting nowhere
    Can anybody Help
    James
    Last edited by SMDFlea; 06-03-2021, 06:56 AM. Reason: added "BN44-0260A" to thread title
    Re: Samsung 32 Inch power supply problem
    Hi looking through the forum I find that the post from Moolink on 07-28-2012, 03:43 AM is basically the same set. But the diodes in my set seem to be OK. The fault occurs with or without the main board connected
      What voltage do you have on inductor LM851
      If it is pulsing then I would lift one end of LM851 and check the voltage across CM852 and if it is not pulsing then I would check QM853 However if it is still pulsing then I would check DM851.
      I can't find a schematic but I did find this
      https://archive.org/details/Samsung_...0260A/mode/2up
        Check the voltage across CM804 and see if it is steady (around 20~25vdc) CM804 or CM808 could be bad. You should also check the voltage across the main cap CP815, this voltage should be around 385vdc if the pfc circuit is working.
          Hi Guys
          Thanks for the help. I found the voltage across CM804 was only 12v. Changed the caps didn't help . Found Zener diode ZM801 faulty
          Thanks for the assistance
          James
