Repairing faulty ANKO AO8606 air fryer
    We have an ANKO AO8606 air fryer that suddenly no power. I pulled it apart and probed the AC-IN, but wasn't getting voltage (or continuity from the plug to the PCB in the air fryer).
    I dug further and found a thermal fuse in the middle. No continuity on the fuse (but continuity on the plug > fuse, and fuse > pcb. but no beep on the fuse itself.)
    Now looking to buy a replacement fuse and heat-resistance sleeve to see if that fixes things.
    Anyone know if this fuse will be ok?https://www.ebay.com.au/itm/18483244...YAAOSw7I9hK0S5
    ^ I can get 3x fuses (couple of spares) for $7, otherwise cheapest I've seen is 1x for $7.50 (Australian dollar)
    Also, the heat resistant sleeve. Are these ok,
    https://www.jaycar.com.au/high-tempe...sort=relevance
    https://www.ebay.com.au/itm/32492254...0AAOSw6i1hsaA-
    Re: Repairing faulty air fryer
    the fuses you linked are o.k. if the fryer isnt using over 10A
    just remember to not get the fuse hot while your fitting it - a classic noob mistake
    either freeze it before soldering or clamp a pair of grips or something to the lead to take away the heat.
    better yet - use crimp terminals.
      Thanks Stj ,
      According to the sticker, it's 240v, 1800w. So that should be about 7.5amps?
      oh wow, thanks for the tip . The thermal fuse that was in there seemed to be crimped in,
      I've actually been looking at getting a pair of crimpers and some terminals. Just a basic set like this
      https://www.bunnings.com.au/supatool...inals_p6010367
      or
      https://www.supercheapauto.com.au/p/...=en_AU&start=1
      Nothing flash, but should do the job for someone who doesn't do much electronic work ?
      Thanks again
        You could do a quick check with your meter:
        Measure from both live and neutral to ground (if it has one) to make sure it is open.
        And then measure from live to neutral and make sure you have a sensible reading: for 1800w at 230VAC that would be around 30ohms for the heating element.
          Hey Per Hansson, thanks for the reply
          not too sure what you mean. Here a pic of what IO'm looking at. A couple of the connectors have been removed during the teardown.
            The wires are labeled, just measure the AC wires to the green/orange ground wire to make sure the readings make sense (no connection).
            And between the AC leads something in the range of 1800w as I wrote above.
