I have Sharp MX3100n printer that recently developed a fault and duplicates either yellow or magenta colour as shadow on all documents printed on either thick 1 or thick 2 papers. Please, can anyone help me discern what the fault is? Some techs have not been able to truly say what the fault is. Thanks.
SHARP MX3100N duplicating yellow and magenta colours
Re: SHARP MX3100N duplicating yellow and magenta colours
It seems that it may be caused by misaligned heads. Some printers usually have an automatic alignment system. I have never used color toner printers, so I can't tell you exactly how to fix it.
Maybe, if you go into print properties on a PC, you will see an option similar to "Align ink cartridges". Some printers usually print a template and then you need to scan it to allign the cartridges
