Hello Everyone,
I received a gift today from my younger brother (probably because my birthday is just around the corner )
He came home from his friends place this afternoon and took home a Gigabyte GA-8IDX Rev. 1.0 motherboard.
It's a Pentium 4 socket 478 motherboard that runs on SDRAM.... something that I've wanted for a long time.... I know DDR is better and I have all DDR systems, but I have a boatload of PC133 SDRAM which would cut costs if I plan to use this motherboard.
This motherboard also has 6 PCI slots and an AGP 4X slot which would be very good for me in building a homework/study PC.
You have probably guessed by now that it has a bunch of bad caps.... and yes there are bad caps on that board.
There are 3 GSC 3300uf 6.3V 10mm caps near the CPU.
The 3 GSC caps are all leaking electrolyte and will need replacing. I've just gone through my draw and I found one Sanyo WG 3300uf 6.3V 10mm cap.
The rest of my spare caps are Hitano 3300uf 10V 12.5mm, and they won't fit.
I've got some 2200uf 6.3V 10mm Panasonic FJ caps coming this week.... would they be OK for replacing the bulging GSC caps?? My brother's friend said that this motherboard was very stable when he took it out of service.... he only took it out of service because he feared that the bad caps could cause some damage to some other parts in his PC some time soon.
On the board, I can also see that there are itty bitty GSC caps with 330uf 25V ratings. They are domed, but are domed inwards.... does that mean that they are bad??
I can see that the CPU output caps are 1000/1500uf 6.3v 8mm Panasonic FJ series caps so they are fine and won't need replacing.
I am wondering if I should also replce the GSC (or Choyo??) 1500uf 16V caps for CPU power input?? They look fine (no bulging etc.) but being GSC or Choyo caps, could they be dry inside the cap itself??
I also tested the board with my socket 478 Celeron CPU and the board POSTs so I can confirm that it does work.
The board smells a bit of nicotine though because it was in a house with a smoker. This PC was in my brother's friend bedroom so there was less smoke/nicotine smell in there , the PC was by the Window so that acutally helped a lot in reducing the Nicotine to stick inside the PC because the Window was mostly open ans also the case had no case fans apart from a CPU fan so there wasn't much Nicotine being sucked into the case.
I am not going to wash this motherboard with water or anything apart from vacumm it off all the dust (which I have done).... it isn't as bad as some boards that I've seen.
Thanks.
Thanks.
