you will probably find 6V3 caps can be used
you must if you want long life out of them use quality low ESR types
(which is "not" the stuff you normally find at hobby electronics store)
it better to go a little up then down normally.
HTH welcome
Cheers
You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
It's an etower 400i3, can't find the model no. of the motherboard (haven't taken out of case yet). But i've done everything possible to determine why it keeps having random reboots. There is one cap with brown leakage on top and it is blown out on one side.
Thank you for the quick responce
you must replace all caps of the same brand/series on that board
not just the bad looking one
visual failure is only one type of failure.
it is not a good idea to reduce capacitance
if it was only one cap then ok to reduce from 1200 to 1000 but when there is many caps then the total capacitance reduced too much
1500 is better and what i would do
