Macbook A1534 2015 820-00045-A CleanMe Bios Dump
    hi friends i need Macbook A1534 820-00045-A Bios Dump with clean me thanks in advance
    Re: Macbook A1534 2015 820-00045-A CleanMe Bios Dump
    anyone
      post your dump, i will try to clean it
      Im Back... sort of...
        with this bios its became very slow plz clear me
          Try and report..
            with this no display i post his original then plz clear me and pass
              here it is orignal bios with pass
              plz clear pass and clean me
                try and report...
                  Originally posted by Claudiomfa View Post
                  try and report...
                    @Murtaza527
                    With original file the laptop have image?
                    whatĀ“s the problem of the laptop?
                    try with this file
                      @Murtaza527
                      try with this file
                      yes with orignal have display i use one extra bios chip for your bios which earlier you clear password but with that was no display i think because of my bios chip just now i write his orignal bios on that chip with that also no display. i try find same ic first then i do your bios and i post result thanks a lot for help
                        try this and post reply use clear pram and reinstal ios
                          Flash my bios on the original ic chip. Maybe you ic chip isnĀ“t compatible with you motherboard
                            Sorry for late reply i flash on original ic both all upper files but with that no luck no display with original have display but have password plz someone clear password
                              Your original dump without password.
                              try and report
                                try and report
                                thank you very much now working fine no password
                                  try and report
                                  this bios is ok but have inside serial number can someone clean serial number plz
                                    Try it for yourself https://www.youtube.com/watch?v=-O1330jgW9g
