UN55D6000 Blinking Standby Light
    Re: UN55D6000 Blinking Standby Light
    Very unlikely to be bad caps on a new TV like this... not saying it's impossible, but it's unlikely. Startup capacitor if anything could cause fault.
      Could a bad start up cap cause all voltages to be output AND cause voltage on the input pins ?
        Originally posted by tibimakai View Post
        If I remember well, there should be a flip up tab and then squeeze and pull.
        Thanks I will try that.
          Some discussion here leading to main board conclusion.
          http://www.justanswer.com/tv-repair/...-warranty.html
          No schematic I'm afraid.
          The guy in the article never came back and confirmed the suspicions of the tech. FWIW the previous owners of this set stated they took it to a local shop and he told them the mainboard needed replacing. Don't know if this is a "common knowledge" thing or what.
          I can understand the possibility of the mainboard being defective but I can't understand why the PS is acting the way it is.
          Perhaps that is its normal operation without load ?
            You could try applying a light load, around a few watts, to see what it does.
              Does Samsung use active LOW for PSON ? That would explain some of what I'm seeing here. As far as voltage on that line without the mainboard connected I can only guess that PSON is a bi-directional data line for which there is some chatter between the mainboard and power supply at power on. THAT would fully explain what I'm seeing. That and the fact that I may have a defect in my led strip(s) causing the PS to respond with an error back to the mainboard.
                mmartell, I was pointed here by the post you made in the other UN55D thread. As you saw, I have the same set with a cracked screen. If no one else answers your question, I'll try to get the answers tonight.
                  Hi johnboy, I have answered a few myself.
                  There is a tab that flips up on the lvds cable connector nearest the board that allows you to squeeze the connector (as one might expect!) and remove the lvds cable from the socket. With the T-Con disconnected I still had the same symptoms.
                  This set does use an active low for PSON. It is 3.3v in standby and pulled low for power up. Since I see voltage on that pin even with the mainboard disconnected I believe I have at minimum a problem with the SMPS.
                  I'm considering using a PSU from a different Samsung I have here and rigging it to see if I can at least get the mainboard to stop flashing and power up properly. Will have a look more at that tonight.
                    I got this info for a UN55D3003 might help
                      Thanks tank will have a look.
                        Ok need some help here thinking this out.
                        I believe I have a faulty power supply. 5V Standby is rock solid. However when the secondary voltages come up the unit shuts down (protection ?) and the cycle starts over again.
                        I think there is a short because I'm reading voltages on the PSON, BLON and DIM pins.
                        Doesn't sound like a capacitor issue does it ? I've heated the board anyway with no change.
                        Where should I be looking ?
                          Here are some pics of the board. Is there some common area that would leak voltage to the input pins ??
                            Hi, I have a un40d6000 with the same symptoms, all voltages are switching
                            on and off, except for the 5vsb.. , ordered a psu, installed it no change, i also disconnected the t-com still no change, i can't find schematics for it,
                            i ordered a main board will post when i recieve it .
                            Peace.
                              Hudey do your backlights come on at all when you plug it in with mainboard disconnected ?
                                FYI, yesterday when I was stripping my tv, I had the LEDs unplugged and tried to fire it up. The led on the front flashed over and over and the PSU clicked repeatedly.
                                  Well having bad leds is a possibility too but I don't know how to test the strips when I'm not sure in the first place if my power supply is good.
                                    Pins 3 and 5 are physically connected on the psu ill try to post a pic
                                    2, led panel will not light , main has to keep the psu fully on, some can be tricked to stay on , i will have to look into it , w/o schematics its kinda hard.
                                    i still have not received the new main yet. will post as soon as its in,
                                    Hope this helps,
                                      Yes it does help, Hudey, thanks for chiming in and do post back with results.
                                        Hi, the main board fixed it. , un40d6000 . same board different f/was a un55d6000
                                        Good luck , Peace
                                          Ok thanks for the update. Since I need a mainboard as well I'm tempted to upgrade to a 6400 or even higher if I can confirm compatibility.
                                          I still wonder if the eeprom is messed up. The voltage regs are working - at least during the "on" portion of the cycle.
