HP Probook 450 G1
    HP Probook 450 G1
    Hi
    I have a strange fault with this HP probook 450 G1.
    When I plug in the power starts the laptop himseslf , spins the fan fast, no screen and flash the caps lock + numlock 7 times white. , all the power supply's are there.
    I have no schedule.
    Can somebody help me what can be the problem?
    best regards
    Steve
    Re: HP Probook 450 G1
    i dont see 7 blinks in hp manual. after 6 blinksisonly continuous blinks
      Hi sorry i was wrong it is 5 times blinking.
        Check cmos battery.Flash bios.
          I replaced the cmos battery is the same
            Anyone has more ideas
            Regards
            Steve
              have you tried a clean bios? ..
                No not yet i ordered a bios programmer. What number do i need for asking a dump. I have never flash a bios. I order ch341A programmer
                Best regards
                  Hi what numer do i need to ask a. Biosdump and flash the bios.
                  What also strange is when i will power up the laptop with mu power supply or another hp charger or my toshiba charger with adapter piece the charger light blinks then.
                  Is the problem then the bios?
                  Best regards
                  Steve
                    5 blinks is general system board failure
                    board is checking charger with middle pin if it is original charger and if it have enough wats. if not it wont let u charge or power on
                      Thanks for the reply ktmmotocross.
                      so when you do not have a original charger you can never test the board then?
                      How can I fix this laptop then?
                      Flash bios?
                        flashing bios is mostly the first to do. next is checking all voltages and power line resistances
                          Ok because i have no flashtool so i will order one ch341 is good enough?
                            hi everybody I got finaly my bios programmer, i will like to flash my hp 450g1 , i bought ch341A programmer black edition , but the chip couldn't be recognice. whe i look to the model is not listed.
                            it is MXic mx25l6473E chip. how can i flash this with ch341a programmer
                            this i hp probook 450g1 wit the 5 times caps lock and numlock blinking problem
                              u cannot have problem flash it. if it is not detected just manually select its series
                                Doesn't excist in the list the bios chip
                                  hi i found the solution after a lot of search i found a new version of ch341 program that support the chip. In attachement the new version enjoy it.
                                  but i can not upload it why? it sys invalid file
                                    There is no attachment in your post.
                                    Btw I wrote you six hours ago in your other thread what to do.
                                    Become a Badcaps supporter
                                    Thanks to all supporters.​
                                      i know i can not upload it says invalid file but why?
                                        i know
                                        So why you perform "a lot of search" then?
                                        Because allowed file types for upload are:
                                        doc
                                        gif
                                        jpe
                                        jpeg
                                        jpg
                                        pdf
                                        png
                                        psd
                                        rar
                                        svg
                                        txt
                                        xls
                                        xlsx
                                        zip
                                        That's why.
