Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 12-19-2021, 01:50 PM   #21
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: EBC-B20H 20A 12-72V Lithium Battery capacity tester just bought one
now those are big inductive resistors...
eccerr0r is offline   Reply With Quote
Old 12-19-2021, 05:07 PM   #22
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
Quote:
Yeah the outer ends are 2 ohms and the center are 1 ohms on each one
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 12-20-2021, 01:44 PM   #23
redwire
City & State: Alberta
My Country: Canada
people are using ESR meters, isn't this a better way to test batteries?
redwire is offline   Reply With Quote
Old 12-20-2021, 03:55 PM   #24
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
ESR meters will measure specific power, but won't specific energy.
Old 12-20-2021, 03:58 PM   #25
sam_sam_sam
My Country: USA
I have read this as well but I do not know how to interpret the results of what the ESR value would mean for battery cell health that you could rely on
I have tried this but I have had mixed results so I do not use this for an evaluation method
Old 12-20-2021, 04:53 PM   #26
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
ESR just needs to match the manufacturer's specifications, comparing numbers across chemistries and sizes doesn't make much sense - a value acceptable for alkaline cells can be horrible for NiMH and Li-ion but too good for lithium thionyl chloride.
An apparatus such as this is still needed to measure capacity.
Old 12-21-2021, 07:31 PM   #27
sam_sam_sam
My Country: USA
ESR just needs to match the manufacturer's specifications Li-ion
Where do you find this information on the data sheet because I always see this
Old 12-21-2021, 09:00 PM   #28
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Depends on the manufacturer, they should list it, if they aren't then they're not doing a good job describing their product. This data is related to the max current draw and thus power.
Haven't checked out Li-ion cell datasheets in a while but I definitely see it for lead acid batteries.
Old 12-25-2021, 12:18 AM   #29
sam_sam_sam
My Country: USA
Well I have had some time to play with this battery testing machine on a battery pack and the software on the computer and it has been interesting with the results of this battery pack
Well my computer decided to lock the screen and I had restart the the software again and lost the results which I do not understand because it has been turned off to not lock the screen however it does it anyway sometimes by it self
Old 12-25-2021, 03:54 AM   #30
sam_sam_sam
My Country: USA
Here are the results after more than two hours into the testing
File Type: jpeg C4B82462-5B93-4701-B651-04E6E181DC9B.jpeg (551.0 KB, 9 views)
Old 12-25-2021, 06:20 AM   #31
sam_sam_sam
My Country: USA
Here it is after more than 4 hours of testing
File Type: jpg 1D4F4C99-637A-40C6-B898-966D53D5F1E6.jpg (203.0 KB, 13 views)
Old 12-25-2021, 01:31 PM   #32
sam_sam_sam
My Country: USA
The end results are that it tested at 7200 milliamperes hours and I do not think that cycling it more will not help because it has tested this way several times before and the results are basically the same
Old 12-26-2021, 04:46 AM   #33
sam_sam_sam
My Country: USA
The conclusion of this battery testing machine is that it is useful for battery packs that are over 24 volts and for battery packs that you want to put more than a 2 amp load on them but it has it limitations one being that you have to have a external switching power supply for charging and your battery voltage has to be above 9 volts to able to use it
It voltage range is from 12 volts to 72 volts which works for me very well I have found a 60 volt switching power supply for this battery tester that I going to buy for it
One more note you do have to modify the fans if you can not stand for the fans to be at full speed all the time when in use
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
