Hi all, I picked up a liquid damaged Asus TUF Gaming F15, does not power on, model FX506HM-HN004T.
Ive gone as far as removing the case and doing a visual check, there is no visible corrision, upon plugging in the power brick a single led light shows that power is plugged in, but no display or fans, the PCH chipset gets warm/hot to the touch, could this mean its not fixable or do I proceed and remove the motherboard completely and check further for shorts etc, failing that should I just take it to a service centre and go from there
what would you do? my skillset is limited but I know my way around soldering and replacing components
thanks in advance
thanks in advance
