Ideapd 5 15ITL05 wont charge battery
    Hello friens , i have a Lenovo Ideapd 5 15ITL05 wont charge battery, so i have these escenarys
    laptop with battery and charger plugged.... laptop power on but wont charge battery and no detect the ac adapter
    laptop only with ac adapter plugged .... laptop power on but wont charge battery and obvuisly no detect the battery
    laptop only with the battery plugged .... laptop power on but wont charge battery and obvuisly no detect the ac adapter
    does somebody has a working bios dump for this laptop, the MB is NM-D211 Rev 1.0
    Re: Ideapd 5 15ITL05 wont charge battery
    Start with checking the DCIN mosfets for being internal shorted.
    BIOS request goes into another category here iirc
    FairRepair on YouTube
      The laptop and motherboard power on with the adapter, so i dont think this problem is related to DCIN mosfet, you rigth, bios request is in another category
        That's a interesting attitude. Good luck by solving your fault.
          Hi like Sepiroth said check the dcin mosfets if the second mosfet is shorted between drain and source then will pass the 19v and the laptop will work on the adapter bit will not work on battery and will not charge the battery. See the beginner guide from Piernov.
          Regards
            I just fixed a Lenovo with the same symptoms as yours. It was a bad DCIN mosfet causing the issue
