Re: TOSHIBA C50-B-14F works but no charging
Have you changed the high side mosfet on pin #18 yet?
Try it with a fresh mosfet.
Measure again the voltages after replacement on pins #18 and #15 of the charger IC.
You can consider to replace the charger IC but the voltages appear to be ok for each pin.
With the ac adapter connected, the battery connector appears to have enough voltage to charge the battery pack do this would imply the high and low side mosfets are working properly. The low resistance in the mosfet checks is of a concern. Or at least remove the mosfet and check their resistance while they are off the logic board.
