Thanks a lot.
With your help, i restored my previous state (cpu fan, power button,..)
My original problem was the display but i think this is a graphical problem ( i was dealing with before the bios problem arrive). So back to work Take care of yourself
When the button is pressed, the LED is on. 0.06 amp remains.
Could there be an IT8995E program error ?
my programier Vertyanov
Ite has 3v on the legs 26, 50, 92,114, 121 when power is inserted into the motherboard
thanks
thanks
bios consisting of the original + update site + clean me..you will not need an EC bios because at Asus when the bios is changed, the EC bios is automatically updated at the first start after the new bios ...
Is it dump OK in case if HUB Cheap was replaced to a new one?
Thank you.
It's a redundant question - the file name contain "ME Clean" witch means yes, it's OK for that purpose.
---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters. ----------------------------------------------------------------------------------------------------------------------------------------------------------
Thank you.
It's running but found out another problem:
I replaced HUB on ASUS main MB1504 (201) X550VX with i7.
And put RTL8821AE wifi module (I attached it. It is ANATEL Combo module) from the same MB1302 (202) X550VX with i5.
But it works only in BT mode. MAIN cannot recognise it at all.
So, mainboard with i7 processor wears different wifi module (only brand) but with the same RTL8821AE cheap. (I attached it. It is as a AzureWave AW-CB161H module)
I guess it's BIOS issue, don't it?
Or Is it HUB replaced problem?
Or must I use only the same AzureWave AW-CB161H module?
