Remove_SMM... UEFI.
    Thinkpad
    Good day Everyone please i need patch for X1 CARBON THINKPAD
      Re: Remove_SMM... UEFI.
      please i have thinkpad P1 i7 8 generation with password TYPE 20ME
      can you patch this file
        Having trouble with x240.I used a patched file that i successfully used on anothe one that worked (No more SVP).Evrything goes fine like it should but when I press F1 key it shuts down.Attached the original dump,and the patched file that i used.
        NOTE:WITH NON PATCHED LENOVOTRANSLATE IT BOOTS NORMALLY AND ASKS FOR THE CODE CORRESPONDING TO HWID.
          @bachir2004
          Try to use the file that has previously worked, but use a locked hard drive (to activate the patch and prevent laptop from shutting down).
            Originally posted by AAAC View Post
            @bachir2004
            this is exactly what i did,same file.with locked hdd it shuts down immediately after display comes on.
              try this file
                Thanks Ghamidi.I will try it and let you know.
                  Originally posted by Ghamidi View Post
                  try this file
                  worked like a charm with locked hdd while pressing the black button.many many thanks.
                    happy for you
                      Re: Thinkpad
                      Good Day Everyone, i have finally patch it on my own, Thanks Everyone, but i have issue and i need help.When i use my own patch, it works but hang on the logo, i have tried it with lock hdd and also press the black switch. i want someone to help me look at my patch file. Thanks
                          For Lenovo X270 I patched BIOS by other dump and worked. Thanks.
                            I have a T480s and a T470s.
                            I have patched them both with the LenovoTranslateService and BootOption images found on this thread replacing them with uefi tool but they both hang at boot after a musical tone and black screen.
                            User tdelfi patched my T480s and it worked now I am trying on the T470s by myself and I don't understand what I am doing wrong.
                            I've read other people saying the problem is related to the ME.
                            HOW DO I SOLVE IT??? What am I missing?
                            Thank you?
                              Re: Thinkpad
                              Try this file and comment, regarding what you did wrong it is very difficult for someone to know it, you have to spend a lot of time to trace what you did in the file ...
                                Thank you?
                                Upload your bios backup here.
                                  Re: Thinkpad
                                  Good day Everyone, NOW is showing Hardware ID :6809683,please i need the key.
                                    Re: Thinkpad
                                    Originally posted by akintunde View Post
                                    good day everyone, now is showing hardware id :6809683,please i need the key.
                                    481489
                                    Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
                                      aldopc, I have successfully unlocked the 470s with another patched bios for the same model I downloaded from a previous post on this thread. I just want to understand the process for personal knowledge and learning.
                                      I attached both my original dump and the version I patched with the LenovoTranslateService and BootOption.
                                      I've read that I need to modify both SSV2, FTW and EVSA using UEFITool NE, but this is the part I don't understand, could you explain it please?
                                      Thank you for the help.
                                        Re: Thinkpad
                                        Originally posted by Karol View Post
                                        481489
                                        Thank you very much. It work perfectly
                                          Re: Thinkpad
                                          Thanks thanks thanks
