LG TV 47LW5500 does not power on (PSU EAX62865401/Main board EAX64405501)
    My LED died while checking on PS-ON test not seeing any voltage.
    Here is result on PS-ON Pin 1 jump to Ping 9-10-11 or 12 (3.5V)
    23 - N.C -> 0V | 24 - ERROR -> 0V
    21 - 12V -> 0V | 22 - PWM -> 0V
    19 - 12V -> 0V | 20 - N.C -> 0V
    17 - 12V -> 0V | 18 - DRV-ON -> 0V
    15 - GND -> 0V | 16 - VSYNC -> 0V
    13 - GND -> 0V | 14 - GND -> 0V
    11 - 3.5V -> 3.52V | 12 - 3.5V -> 3.52V
    9 - 3.5V -> 3.52V | 10 - 3.5V -> 3.52V
    7 - GND -> 0V | 8 - GND -> 0V
    5 - GND -> 0V | 6 - GND -> 0V
    3 - 24V -> 0V | 4 - 24V -> 0V
    1 - PWR-ON -> 0V | 2 - 24V -> 0V
    Re: LG TV 47LW5500 does not power on (PSU EAX62865401/Main board EAX64405501)
    10 years or more LED LG old and now the reading of voltage not correct listed ..however i can tell one things.... you have back light issue
      I disconnected backlight cables and tried PSU test still no voltages
      if I put 201 cable to board relay keep turning on off and voltage comes and go
        LW series has BGA failures. Search ebay for repair services.
          BGA is on mainboard not on PSU, I need to fix PSU voltages before going into Mainboard, also shipping board to China will cost more than LCD price instead I can install Universal Android board but for that I still need PSU FIX and have backlights working
            If you jump PWR-ON to 3.52V STBY, why does it show PWR-ON = 0V?
            When you jump it, did you disconnect the cable from the power supply to the main board first? If you did not you can damage the switched Transistor on the main board.
            You should always use the resistor to force on the board, in this case you can use 100 ~ 500 Ohms resistor.
              My apologies yes PS-ON had 3.5V it was my typo. and yes I did disconnected cable from main board and used resistor to jump PS-ON to 3.5V
              only voltages I am getting is 3.5V on Pins 9-12 (and get 3.5V on PS-ON when jumped)
                OK.
                So if you run the power supply board by itself, you jump the PS-ON pin but the switched 12V/24V still do not come on, we need then to find out if the PFC Voltage booster is working or not next.
                Please check the Voltage between the two legs of the main filter caps (the three of them with 450V rating), they should have about 380 ~400VDC when you jump the PS-ON.
                BTW, there are 3 fuses (1 for ac, 1(with two dark color bands) for 12V/24V power supply, 1 for standby power supply. Is the one for 12V/24V OK?
                  all three caps has 275V and fuse it fine
                    That is very low.
                    What is your AC line Voltage, 230V? If it is 230V you should have about 325V when not force on, about 380 ~ 400V when forced on.
                    Are you sure you're only getting 275Vdc?
                      yes its 275V (sometimes it goes to 278/285) and yes I am on 230V
                      with force off I am getting same 275V
                        275VDC on the main caps is not right all.
                        Can I see good clear straight shots of the whole bottom side of the power supply board?
                        BTW, do you hear the power relay clicks on when you apply the force on (jump)?
                          attached
                            forget to mention relay click, yes I do hear relay click sound and I verified rectified has same 275-278VDC with force on
                              https://www.badcaps.net/forum/attach...8&d=1596433739
                              I only see Black probe on Neg. leg of the cap. Where did you put the red probe at?
                                https://www.badcaps.net/forum/attach...9&d=1596433739
                                I need straight shots pictures of the board, not in angle like that, because I need to be able to trace out the traces on the board to see what is going on.
                                  I put red prob on positive of cap
                                  I hope these pictures are usefull
                                    Are you sure the meter is good on 1000V scale?
                                    The pictures are much better but can you show the whole board, it is hard for me to trace out the circuit without seeing the whole board.
                                      BTW, check the AC Voltage on the two inner legs of the bridge rectifier to see what you get.
                                      It's 1:40 AM my time here so I will have to do follow up tomorrow, may be some one will look over also and help you out. Good night.
                                        sorry I went to sleep, i'll post whole board pic shortly.
                                        Bridge rectifier had 220V in inner legs, that was first thing I checked after relay click.
                                        i'l measure reading again with different meter.
