Acer R3 Bios
    Acer R3 Bios
    Somebody plz share bios dump for Aspire R3-471TG.
    DA0ZQXMB8E0 REV E
    Re: Acer R3 Bios
    Post your backup, maybe someone can help you.
      Re: Acer R3 Bios
      having backup of both chips would help... i could extract it from acer suport site but i need example to know where to cut
      Im Back... sort of...
        Re: Acer R3 Bios
        Here
        Techman1025
          Re: Acer R3 Bios
          go to the acer website and check there got mine form there
          https://www.acer.com/ac/en/US/content/drivers
            Re: Acer R3 Bios
            Actually there was no bios chip, removed by somebody. Bios from Acer support is encrypted. I will test attached BIOS will inform if it works.
            Thanks everybody.
              Re: Acer R3 Bios
              Sorry to say techman, attached dump didn't work.
                Re: Acer R3 Bios
                Hi
                Ok confirm want was tested ? First whats your problem with computer ? whats it doing with old dump and new dump. Did you test RSMRST 3.3v & S5 3.3 VOLTS is it present ? secondary voltage present external keyboard or mouse lighting up or if you press caps lock does it light or even external mouse either or . Let confirm for sure it's a bios problem if it is i will help you fix it.
                techman1025
                  Re: Acer R3 Bios
                  @techman1025
                  Every voltages are good but no display. Capslock won't light up.
                  RAM ok, led panel ok, lvds cable ok.
                  FYI, it's a discrete version with touch.
                    Re: Acer R3 Bios
                    @techman1025
                    I have look the bios was you upload, there is something wrong I guess, ME region was missing. Please take a look again.
                      Re: Acer R3 Bios
                      lets stay simple here
                      on acer website there is no full bios update only partial, no me region or descriptor
                      in ver 1.09 it looks like there is ec update also, lots of region and lots of work to reconstruct bios
                      anyways if someone have account pls download and attach here
                      http://**************/dump/kompjuter.../426-1-0-39949
                        Re: Acer R3 Bios
                        if I share it from remont, will banned forever. already download from s***forum. Let you to rebuild again.
                        check PM please, already send link the dump from s***forum.
                          Re: Acer R3 Bios
                          try this
                          https://drive.google.com/file/d/0B1t...ew?usp=sharing
                            Re: Acer R3 Bios
                            Thanks again.
                            I'm confused about file size of 26mb ala_borbe?
                              Re: Acer R3 Bios
                              2 bios 16bm each
                              try one, if does not work, try other
                                Re: Acer R3 Bios
                                But I have 8mb chip only.
                                I can see me ver 10.0.30.1072 is 5MB, can you compile with 1.5 one.
                                  Re: Acer R3 Bios
                                  i could try but only if you confirm working or not
                                    Re: Acer R3 Bios
                                    @ala_borbe
                                    I expect your upload is good but I'm sorry I can't test becoz I don't have such bios chip.
                                      Re: Acer R3 Bios
                                      thay are not expensive
                                      http://www.ebay.com/sch/i.html?_from...25q128&_sop=15
                                      also i dont know will it work, it need to be tested
                                      strange bios on this mobo
                                        Re: Acer R3 Bios
                                        Try this from vietnam site:
