Acer R3 Bios
    Re: Acer R3 Bios
    Originally posted by ala_borbe View Post
    thay are not expensive
    http://www.ebay.com/sch/i.html?_from...25q128&_sop=15
    also i dont know will it work, it need to be tested
    strange bios on this mobo
    Originally posted by dspok View Post
    Thanks again.
    I'm confused about file size of 26mb ala_borbe?
    Yup..a bit make me confuse too. From remont only 8mb, but from s***forum have 16mb.
    I rebuild again Intel and ME region taken from remont, the rest from official update 1.09. Hope it's work if you want to try it. Rebuild only 8mb following file from remont.
    Have reading schematic, U24 W25Q64FVSSIQ -- 8MB. Is there a possibility the schematic to cheat us?
      Re: Acer R3 Bios
      @meritosari
      Attached bios v1.09 worked, thanks a lot.��������
        Re: Acer R3 Bios
        @meritosari
        respect in skill and a way of thinking
        what did you use to recompile with smal me... fitc?
        Im Back... sort of...
          Re: Acer R3 Bios
          @ala_borbe
          I already tried with fitc but it doesn't compile 8mb instead compiles 3 files two 8mb and one 16mb. Both 8mb files doesn't include me and bios region.
            Re: Acer R3 Bios
            By the way meritosari how did you extract bios region from Acer support, I see that was encrypted.
              Re: Acer R3 Bios
              @meritosari
              I think that I was wrong to choose word "rebuild", should be word "mix or fix". I belive that You're best than me about that, I knew it. . Since I gave you wrong the dump as reference.
              The tools that was require has been being on this forum, but I won't mention it. Several thread was mention it. ( I known maybe only clue, like a puzzle you should find it your self ). The key is you should have original backup even it's not working bios.
              The only one thing what I'm think now is if using bios from another laptop, then there are two kind laptop with same unique ID....That's why HP need fix DMI to avoid double Unique ID. Also other reason is SN windows original store on chip.
                Re: Acer R3 Bios
                Thanks alot work done ok display tested
                  Re: Acer R3 Bios
                  Ok tested thanks all
                    Re: Acer R3 Bios
                    Originally posted by techman1025 View Post
                    Here
                    Techman1025
                    hello please somebody help me to remove password in this bios
                      Re: Acer R3 Bios
                      any help
                        Re: Acer R3 Bios
                        Originally posted by Pascal Komlassan View Post
                        any help
                        Yes, you have to be patient. If it doesnt work go to bios-pw.org .
                        24A000 - 24A030 W
                        240000 - 2400FF D
                          Re: Acer R3 Bios
                          Okay thanks bro
                            Re: Acer R3 Bios
                            try this.... i test some new method to remove password from original bios
                              Re: Acer R3 Bios
                              @meritosari
                                Re: Acer R3 Bios
                                thanks you this work forme
                                  Re: Acer R3 Bios
                                  TNX @ala_borbe.... it works....^_~
                                    Re: Acer R3 Bios
                                    Salam kenal, Pak Meri
                                    After so many bioses i've tried, this v1.09 works for me!
                                    Thanks. Terima ksih , pak.
                                      Re: Acer R3 Bios
                                      Hi could you please upload the 1.09 file again Because this package is corrupted some how.
                                        Re: Acer R3 Bios
                                        nothing corrupt ... update winrar or use 7zip ..
                                          Re: Acer R3 Bios
                                          v1.09 didnt work for me.
                                          My laptop is touchscreen with graphics.
                                          Posting old original bios. Please help.
