HP Elitebook 8560p Bios Dump
    Re: HP Elitebook 8560p Bios Dump
    put it as corrupt as it is ... we have no way to help you, if we don't know what you need ..
      Well, there is an archive attached to this thread, in the second post. The file in it is larger than the size of the BIOS chip this motherboard has.
      The chip is a MX 25L6406E and you can fit in it a 8192 Kbytes file. The file in the archive has 8196 Kbytes so it won't fit. That's the part I need help with.
      As for the reading of the original BIOS chip, I didn't do that as my chips programming setup is primitive and requires soldering wires. I just had an identical chip which I used to write the bin file then I replaced the chip on the board. But the laptop is still not working so I came back to this post because of the dump file attached ...
        I was able to read the original BIOS chip and here is the content.
          give it a try and we'll see ..
            It works, thanks. My I ask what you changed?
              Thanks a lot. Works great
                Originally posted by techman1025 View Post
                Hi
                Always upload original it's a lot harder with out it even if it's bad.
                Techman1025
                techman1025, thank you very much man, it's working perfect
                  Thank you
                    Hello. I have a same model with password and cannot boot from usb. Can anybody help to remove the password for me? I really appreciate it.
                      Originally posted by daudi83 View Post
                      hello. I have a same model with password and cannot boot from usb. Can anybody help to remove the password for me? I really appreciate it.
                      try
                        Thanks i will check tomorrow.
                          Thanks Gayyum its work like a charm
                            thank you
                              hp elitebook 8560p
                              hp elitebook 8560p
                              e89382 hannstar j mv-6 94v-0 bios bin & schemetic please
                                Re: hp elitebook 8560p
                                Originally posted by bdschemetic View Post
                                hp elitebook 8560p
                                https://www.badcaps.net/forum/showth...litebook+8560p
                                  Originally posted by qayyum786 View Post
                                  try
                                  hello qayyum pls does it works for 8560p motherboard with amd vga chip or its only applicable to intel only
                                    I have just unlock the password from dump
                                    btw you can write & test it if it is work for you than awesome
                                    if not than post your laptop model/number/mbd part number & backup dump we will try to fix it or build it again for you
                                      Hello, could anyone help me and modify the serial, pn .etc to get rid of the message product information not valid.
                                      It is not possible to write via the HP DMI Tool, so I test directly via the bios.
                                      Thank you very much.
                                      My bios and values.
                                      HP EliteBook 8560p
                                      Serial: 5CB1505ZP8
                                      Product: WX788AV
                                      Warranty:3y3y0y
                                      Motherboard:
                                      CURE_DIS_HR_HPB MV_MB-V1
                                      P/N: 01015FM00-388-G
                                        Hi
                                        Techman1025
                                        Thank you
                                        100% working
                                          Hi
                                          Techman1025
                                          thanks
