Panasonic TX-L55WTW60
    Have a problem with this TV ...
    The fuse was broken,so I replaced it,but it has blown again ...
    Don't know where to start checking ...
    The power supply is tnpa5817
    thx for advices
    greets
    Darko
    Re: Panasonic TX-L55WTW60
    Decent photos always help. Fuses don't tend to blow without a reason, start with checking the main components on the hot side of the power supply for shorts.
      https://www.dropbox.com/s/kdclm7b2wg...70510.jpg?dl=0
      https://www.dropbox.com/s/wzdtxpcqo0...70522.jpg?dl=0
      https://www.dropbox.com/s/dzxflb7thp...70530.jpg?dl=0
      https://www.dropbox.com/s/u51rtdjvnn...70537.jpg?dl=0
      Here some pics,see the upper right corner,the blown fuse ...
        It's better if you could post your pictures on this site using the "Go Advanced".
          Originally posted by dick_barton View Post
          it's better if you could post your pictures on this site using the "go advanced".
          +1
              That is quite a severe short with the fuse going black.
              Check Q7201, Q7203, Q7301 & Q7302 and bridge rectifier D7102 and diode D7215
                THX
                After checking with multimeter the Q7301 and Q7302 are not showing the right values between surce and drain ...
                But a question,what is their mark,i can't see it on them,and on the shematic there is no value for Q7301 or Q7302 (the PDF doc)
                STB13NM60N - maybe ????
                  Use a magnifier and shine a light on them at an angle to see if you can read what is written on them.
                    Tryed,but last numbers/letters are missing ...
                    Just se the 13NMxx0N the xx is missing
                      They could be STB13NM60N as you suggested earlier
                        Thx all for help ...
                        The parts came on friday,today I put them on the power board,and the tv works ...
                        again thx all ...
                        greets
                          Thanks for the follow up on the successful repair.
                            Hi, trouble again ...
                            The TV worked for 15-20 days ...
                            Same TV ...
                            Now the 2 resistors R7201,R7202 are blowing in the air ... the fuse remains OK
                            Any advice ???
