hey guys , need k54LY bios dump
    Re: hey guys , need k54LY bios dump
    ok mate , tomorow morning ill chek it
    thk in advance
      Hi
      Your model schematic ant release see if this helps
      Techman1025
        so my friend here am i to give some relate about this job , so after making some measurement , i cheked having ldo 5 volts on main regulator aqltough i dont have 5 volts on coil , only 0.96 volts , but the 3.3 line is with the correct value , started cheking SPI pins and noticed having high values of 3.04 volts , on pins 1 2 5 and 6 . thinking about SPI could be on the KB(my bad here , i replacedd the kb but with no joy ) after cheking schematic notice that the spi block was on the BD itself , reflowed the BD but still the same , since i have pratically major parts of spares in stock , lifted the hm65 and replace with a new one ... TCHAM RAMM it turned on .....well not for big joy , i turned it off , once i try to turn on , well dead again !!!!
        ready to close this ... guess it killer the pch again !
        opinions ?? well they are more than welcome !!!
          Hi well what's the out come?
          Techman1025
            have you read the post above yours robert ?
              well we are closing this machine , each time we lift the pch machine will turn on but only once , seems like waterdamage , something weird , is happening and we've lost to much time with this unit allready . thk anyway for does who spent time creating the bios , we will keep it for future reference thats for sure .
              thk guys
                board is a K54LY REV 2.0 search
                  think
                    https://yadi.sk/d/8TBADXOFpUQcR
                    huge dump package for asus bios
                      thanks
                        Just flashed BIOS from ala_borbe (second post) and it's worked.
                        TNX
                          Originally posted by techman1025 View Post
                          Hi
                          Here is the new file i made for you .....if this don't work you have other problem ..to know if bios is working rsmrst 3.3V S5 3.3V do you have it caps light up on keyboard if pressed or usb mouse lighting up if yes to all bios is work enjoy.
                          Techman1025
                          thank you ,its working fine
                            thank you
                              tank you
