Acer E1-470 bios dump needed
    infos:
    EA40-CX MB
    12280-3
    48.4LC02.031
    Intel based system... no display problem on this one...
    Re: Acer E1-470 bios dump needed
    maybe i could help if you read your bios and post it here
    Im Back... sort of...
      Here i got this please feedback
        @cyberhack:
        I tried your file but it ended a dead unit..
        @ala_borbe:
        i attached my backup...
        thanks
          I tried the bios from EA40-HW unit it ended totally dead...
            try this
              @ ala_borbe:
              unit is now ok.. thank you very much for the bios file...
                @ ala_borbe
                THANK YOU SO MUCH, WORKING FINE
                  Gracias por el aporte bios trabajando ok
                    Thanks You
                      thank you
                        thankyou for help, working fine
                          Originally posted by ala_borbe View Post
                          try this
                          Thanks bro its good
                            try this
                            thank you working .
                              try this
                              please help me im newbie here. can i use this .bin bios update to update my bios? thanks
                                the bios from post # 6 is not an update, it is a repaired bios..if the laptop bios is damaged you can use it, but first make a backup of the original bios, if you want an update, post the backup of the bios and someone will help you ..
                                  try this
                                  tnx sir
                                    i have this acer e1 470 can somebody please fix my bios dump.
                                    it has no display.
                                      it has no display.
                                      Did you try post #6...
