Samsung LE40A558P3FXXU Colored lines
    Good evening, I'm looking for some help with my daughters TV please, it has recently developed an issue, When you turn on the unit you get colored lines running top to bottom of the screen, I have carried out some very basic investigation and googling from what I can gather this may be an issue with the T-con, I have check and re seated all the cables running from the av to the t con and the t con to the panel I read about several people have this issue with other models of Samsung and a temp fix by flexing the pcb av or t con until the lines clear,this I have tried with out success, before I go any further I thought I would as for some guidance from you guys.
    Thank you
    Re: Samsung LE40A558P3FXXU Colored lines
    could you show us the issue with pictures or movie.?
    did you tried to feed the set with different source of signal such HDMI or playing video material with USB to see if the issue remain? also did you tried to reset the firmware of the TV?
    also if you disconnect one side ribbon cable between T-CON and panel.. did you got clear white color on half side panel or the lines remain??
      Thanks for the response
      this is the issue
      This it the T-con
      and this is the TV ID Plate
      I have a video, not sure how to add it though.
        that is with no feed, how do i reset the firmware are you able to point me to or provide some instructions on how to thanks.
          forget about firmware or feeding another source.. just do test disconect one side of ribbon i mentioned before and tell the result
            This is with right (looking from screen side) cable removed
            and this is with left cable removed
              You should check the COF cables, probably a loose contant if not there is an short on the cof
                however this test of ribbon removing sgould be done with signal feed cable or sat or areal.. to see the next half how the picture look.. you can do it again with signal..
                i am aware the daughter did clean the screen with spray or wet cloth which some of liquid drops down on the panel PCB boards and make damage to one or more small SMT ceramic caps.. or as usual most time we find these caps got shorted with out any liquid damage too..
                so do the test again with signal.. if same result go to inspect the 2 panel PCB or post clear photo of both side over here... good luck
                  I'm not aware of any cleaning, retest with signal feed = same result. what are you referring to by 2 panel PCB? I shall post some pictures of the T-con and av boards now, I can not see any obvious signs of component failure though you might see something I can not, thank you for assisting me with this.
                    I did find some debris on the t-con connector cleaning it made no difference
                    Is the stain on that component normal?
                    T-con Front
                    T-con Back
                    I'll post pictures of the AV board shortly just got to take them first.
                      2 Ribbon cable which going out from T-CON to the Panel, they are connected on PCB boards of the panel.. take the metal cover of them.. you will see 2 boards left and right... here are the issue..
                        Example of Tab bonding board that you need to get to them to inspect them.
                          Thanks for helping what am I inspecting for please? I can't see anything can you I've added some pictures of the two tab bonding boards
                            Pictures are too low res for me to zoom in to see anything in details.
                              can I upload high res pictures? didn't think I could.
                                In theese models tcon is on the top so cleaning damage is almost impossibile, the first thing to do in theese cases is to check main voltages on tcon, much probably something's wrong, if all ok then processor need reballing.
                                #### NOTE FOR EVERY TV POSSESSOR, EVERY XX YEARS IT IS NEEDED A CHANGE OF THE CONTACT MATERIAL ON CPU AND HEAT SINK ####
                                  Thanks for the info guys, I've had another look at the t-con I can see a gold circle labeled 12VIN i'm assuming this is the 12 input, what should I be using as the negative for test this feed also should I be looking for any other input voltages or outputs? thanks
                                    Metal chassis back for ground.
                                      must know the tcon model code, to find better pictures..
                                        On the T-con is T400HW01 V4 CTRL BD and 40T02-C02 I've added some hi res photos does this help?
                                        I'll do the 12V check today and report what I find thanks.
