HP Probook 650 G1
    HP Probook 650 G1
    HP Probook 650 G1
    CAPS lock and NUM lock blinks 5 times, there is a POST and hangs after that.
    Changed the BIOS, changed RAM, no result/no change.
    Any thoughts, please?
    Re: HP Probook 650 G1
    Have you tried a different CPU fan?
    If this doesn't work, then the system board has probably failed.
      Hi there you said there is post do you see the bios. Are all the power supply present .
        I see POST, then the flashing starts and hangs.
        I will look at Fan and supply voltages.
        Thanks all
          Hi
          You must probably try to clean me Intel region from your bios. If you can not do it self. Put your biosfile with external programmer in bios section. Ask there for to clean your bios and program it back to your board. Tip desolder bios to read the bios. I have the same working laptop here right now.
          Good luck
          Regards Steve
            Thanks,
            I allready tryed a cleaned BIOS from this forum, no improvement
            https://www.badcaps.net/forum/showpo...6&postcount=26
              Ok try a another processor i5 or I 3 4th generation.
              That was by my also the problem. I tried another processor and bird worked with my hp probook 450 g1. They use the same processor.
              Good luck let me know the outcome.
              Best regards
              Steve
                Update:
                CPU changed; no result
                Disassembled the lot, disconnected all FPC cables; got a CMOS RESET Alert, reconnected all, after that problems gone!
                  Did you use the same processor?
                  Best regards
                  Steve
                    Original CPU
                      And all power lines are present? I will upload later my bios dump . And you can try it. Will be later in the afternoon when I am back home. Are you sure all power lines are present?
                      Best regards
                      Steve
                        it's solved, see above
                          Hi Dubbele
                          That is good news. Well done, good job. 😉
                          Best regards
                          Steve
                            Turns out it was the ODD thats generates the error and hangs the system
