RV511 Problem
    RV511 Problem
    https://www.badcaps.net/forum/showthread.php?t=78845
    I tried above still the same issue turns on fan at full speed but no display already tried the bios of piernov on this thread same result. maybe the PCH is dead
    Re: RV511 need clean me bios
    Vcore present??
      grey coil near cpu has 0.89v and caps near cpu has 1.08v
        There should be probably three coils near cpu-2 for vcore and 1 for gfx core. Have you measured all of them??
          the two coil near cpu together has 0v both the other one coil has 0.89v
            So, that does mean you have missing vcore. What's the mb marking? Lets first check schematic avlbl or not. Btw, did you checked fets connected to vcore circuit??
              board id is BA41-01433A. the two grey coil together vcore is beeping all sides to the ground.when i check continuity on the backside for the fets the one fet is beeping it has mark AO6710
                Re: RV511 Problem
                Lets keep repairs in the main forum, and bios requests in the bios requests forum please.
                  Re: RV511 Problem
                  update: i replaced the mosfet 6710 with the same mosfet but still the same issue still no vcore voltages on two grey coils
                    Re: RV511 Problem
                    Don't randomly replace components or you'll cause more problems. Try to understand why they are not told to turn on.
                      Re: RV511 Problem
                      i replaced the mosfet with the same value. it seems that this vcore coils are shorted to ground
                        Re: RV511 Problem
                        Vcore coils has very low resistance to gnd. If its below 005-then it may be shorted. Measure in diode mode with black probe on gnd and red on coils.
                          Re: RV511 Problem
                          in diode mode balck to ground and red to two coils it measure 002
                            Re: RV511 Problem
                            Use resistance mode. Sandy Bridge can be 2-3 ohms without problem. Ivy Bridge can show 1.5 ohms and be perfectly fine.
                              Re: RV511 Problem
                              resistance mode shows 2.2ohms but two coils both sides shorted to ground
                                Re: RV511 Problem
                                Also this has a removable CPU so you can measure without CPU.
                                  Re: RV511 Problem
                                  if i remove the cpu and measured resistance without cpu it shows 1.5ohms
                                    Re: RV511 Problem
                                    anyone can help on this
