Netgear WNDR3300 Issues
    Re: Netgear WNDR3300 Issues
    Eggcellent!
    veritas odium parit
      spoke too soon. my dad is complaining that his netbook keeps getting dropped.
      Any more ideas other than a sledgehammer or a shotgun?
      sigpic
      (Insert witty quote here)
        TNT
        Can you put the original firmware back on?
          Originally posted by shovenose View Post
          TNT
          yes, but it's a pita. also a good way to ruin the network (netgear stock FW is no good for file sharing or IP printing, esp under linux).
          ive had no issues... maybe I'll reinstall dd-wrt...
          sigpic
            Yes, I understand that DD-WRT is better (in most cases)... I have used it on many routers and have had a great experience with it.
            HOWEVER the Netgear stock firmware isn't so bad...
            Why? Because of the recent update.
            A while back, I logged into the cotnrol panel of my WNR2000 and it said I had a firmware update. I did it, and HOLY COW what a difference! They literally redid the entire interface!
            Besides, we know the stock Netgear firmware is 100% compatible, so it's worth using just to test the hardware of the router - if you still get dropped connections using the stock firmware we know something is wrong with the router.
              I read it is a common issue with that model router and DDwrt.
              however, I am not going back... going back would kill all the printers in the house , which are all network printers (one IP, one hooked to the file server). I have not had dropping issues myself... and my dad is using a azurewave wifi module
              I may try a 30/30/30 reset tonight and see if that has any effect (I forgot to do that when I installed, DOH!).
              sigpic
                It was just a suggestion :P
                IMO, you learned something: test a router thoroughly BEFORE installing aftermarket firmware or modding it
                  Those are pretty much junk. My eeePC came with one of them.. nothing but trouble and poor reception. Replaced it with a Broadcom miniPCIe card and never had problems since (and got the added bonus of out-of-the-box OSX compatibility )
                  edit: the Azurewave also only used one antenna (only had one socket) and claimed n-WiFi capability, the Broadcom card is only 802.11g, but has sockets for two antennas. Bought a chinese internal laptop one from ebay and hid it behind the LCD. Can't say it makes a lot of a difference (probably because of the antenna being cheap & cheesy), but it definitely did something.
                    would an intel 3945 be a sizeable upgrade then?
                    his has 2 antenna sockets on the card... not that that means anything...
                    sigpic
                      upgraded the card, the POS won't detect it... maybe you HAVE to use the junk card under windows?
                      sigpic
                        Are you both running wired and wireless in the house from different routers?
                        veritas odium parit
                          the router has 2 radios... but all the routing is done from that router, including wired.
                          put the azurewave card back in the eee pc... installed the latest drivers as well, so far no issues.
                          sigpic
                            added heatsinks, no impovement
                            I read that axing the 2.4ghz radio and setting the 5ghz radio to 2.4ghz fixes it...
                            that means no more 5ghz
                            but other than some old wireless A cards I have somewhere, 5ghz had no use... two of my laptops could see it but the performance was not that much better than the 2.4ghz setting... TBH, I don't see the big deal about 5ghz... it is only good in wide open spaces, which my house is not.
                            any other advice?
                            sigpic
