Hp 650 bios
    Re: Hp 650
    the machine turn on and off all the time , but once i press on the on off , the le near the SDcard reader , turn on and off at each 5 second , turn on , then off , then on then off . , dc jack is ok , led is on , i got 3.3 and 5 once i can turn on the machine (meanwhile the cpu is not getting hot . i notice that coils from memry bank try to start as well , 1.8 then '0 , also for PCH the same , any taughts ?
      Re: Hp 650
      dj ricog , no its a uma board , not discrete .
        Re: Hp 650
        got here the original bios found on the site , and also got here both my dump , any chance of someone split me the original bios ?
        techman or dycc bios expert !?!?? gonna put the files on attachment, gonna add here my main bios , like this you know were to cut the original bios frmo the site , to give me both files EC and main
        mine is maindump.rar
        original 01859.rar
        thk in advance
          Re: Hp 650
          try this main, decompressed image, cut main bios
          dmi not fixed
          Im Back... sort of...
            Re: Hp 650
            i need the EC part as well
            btw your file is corrupt , i can't open it , gives error
            try reuploading again and if you can give me the EC dump as well i apreciate it
              Re: Hp 650
              must have winrar v5+ (newest)
              ec and me will be there tomorrow
                Re: Hp 650
                ok i apreciate mate . thk
                  Re: Hp 650
                  ok, here are files to test
                  4 files here:
                  1. 01859.bin > 5.120kb > full file, decompressed only
                  2. 1-ec-01859.bin > 128kb > should be EC bios
                  3. 2-main-01859.bin > 4.096kb > should be main bios
                  4. 3-unknown-01859.bin > 896kb > unknown module, maybe intel ME firmware, donno, can be ignored
                  sry, i have no hp 650 available to test and confirm it myself...
                    Re: Hp 650
                    thk will try it mate , once you have chance , need to speak with you
                      Re: Hp 650
                      well not a bios issue , or a KBC issue , machine still with same behavior , i press to turn on , and the flash card led blink once at each 5 seconds . all coils got voltage only when flash card led is ON . something on S5 making it to shutdown ... really not cheking what the fault is
                        Re: Hp 650
                        anyone with this schematic ?? i found here a transistor with burned traces , would like to know wich circuit is serving for , to follow first this circuit to make sure there isn't anything damaged.-
                          Re: Hp 650
                          ok got the problems machine is now turning on , but altough no image !!! pfff one after the outher ...
                            Re: Hp 650
                            Originally posted by ala_borbe View Post
                            1. backup you old bios for DMI data
                            2. fix new given dump
                            3. program fixed dump
                            otherwise it will say that its some other model and serial num
                            dumped from
                            "HP Compaq CQ58-384SR
                            newton_cr&hr_hpc mv_mb_v1"
                            different model but same motherboard
                            ec+main
                            Thank you! I try it...
                              Re: Hp 650
                              how did you fix the problem mate?
                                Re: Hp 650
                                eheh dont remember my friend long time
                                  Re: Hp 650
                                  Originally posted by Luís Amaral View Post
                                  Hi, need bios dump for HP 650
                                  Motherboard:
                                  PALWONN M3
                                  Anyone could help i will be appreciated
                                  tested ok
                                    Re: Hp 650 bios
                                    thank you so much
                                      Re: Hp 650 bios
                                      Thank you
                                        Re: Hp 650
                                        Write Both EC & Main Bios,Display Ok But Givan Startup Error System Board is Missing Or Invalid
                                          Re: Hp 650 bios
                                          did you do a reflow
