Trippling internet speed with pare of AA batteries, ethernet cable and electric tape.
    I want to know if I can increase my internet speed by attaching a pair of rechargeable AA batteries and also Sata and IDE cables which are optional to a CAT 5 or a CAT 6 Ethernet cable with electrical tape.
    I heard about this formula and it is called "magnetic induction". It states that almost all Ethernet cables available locally at the electrician store, stationery store etc. have very high resistance compared to Ethernet cables that the ISP uses which have very low resistance. So you can reduce the resistance in your Ethernet wire and amplify the signals going through it using "magnetic induction". Which means if a magnetic field passe through a wire it will create a current and batteries have low internal resistance and are good for both creating and inducing a current. So this is what I heard and it says it can triple your internet speed.
    Can any one confirm that this method does work.
    I am using cable internet with modem and router.
    Re: Trippling internet speed with pare of AA batteries, ethernet cable and electric t
    Sounds made up to me. I've just measured a 20m+ ethernet cable and it's 2ohms.
    Low resistance Ethernet cables do not exist.
      it's bullshit.
      the ISP uses high-frequency coax not ethernet cable.
      also ethernet cat5 is rated for full speed at 100m length - it's NOT lossy!
        When in doubt, use common sense. You pay to provider for X Kb/s. No modification on your cables will triple that.
        That, and reasons. (google it out)
        stay classy
          But if it is on Internet it must be true, not!
          https://www.youtube.com/watch?v=lG5cEik2ABY
          I have a famous red bridge for sale real cheap too.
            Long time badcaps members have been using D cell size batteries to quintuple their Internet speeds since April 01, 2000. Plus, we don't use ethernet cable, but magical hand wound copper wire from old transformers. The turn ratio is a well guarded secret and only 5 badcap members know about it.
            Seriously, his channel of full of clickbait titles and videos just to drive up the viewers and collect $$$ from ads.
            Of course, what he shows is complete BS. If you pay for 5Mbps, you get 5Mbps from the service provider in terms of bandwidth.
            If you are looking to speed up web browsing, then use a browser that supports advanced features. For example, I use google chrome and I use the datasaver extension.
            https://developer.chrome.com/multide...ta-compression
            Or Opera with turbo boost and built in adblocking.
            http://www.opera.com/blogs/news/2016...ac-opera-mini/
            http://www.opera.com/blogs/desktop/2...for-computers/
            http://www.opera.com/turbo
            Using either of the above *may* speed up some of the webpage visits.
            --- begin sig file ---
            --- end sig file ---
              I haven't kept up with the advances done to TCP/IP, but this book from 2014 talks about some of the work being done to optimize web performance. I know that HTTP/2 is now being implemented on some of the largest websites and most up to date browsers support HTTP/2. I should load up wireshark and take a look myself one of these days.
              http://chimera.labs.oreilly.com/book...545/index.html
                I always wonder how much money you can really get from YouTube.
                  Going off topic, but $12 million USD (2015 figures/estimates) according to
                  http://www.ibtimes.co.uk/youtubes-mi...ot-12m-1524384
                  ublock origin is my favourite add-on. Open source and written by a Canadian.
                  https://github.com/gorhill/uBlock
                    "So you can reduce the resistance in your Ethernet wire and amplify the signals going through it using "magnetic induction". Which means if a magnetic field passe through a wire it will create a current and batteries have low internal resistance and are good for both creating and inducing a current. So this is what I heard and it says it can triple your internet speed." I sure like to really know who comes up with that explanation.
                    If you want a good laugh, this one takes the cake!
                    "It's important to use electrical tape , because it conducts electricity"
                    https://www.youtube.com/watch?v=nRmMkiTB_uE
                    I just love reading the comments section.
                      Budm that link was old, Theo Joe was only doubling the speed, here he Triples it https://www.youtube.com/watch?v=nRmMkiTB_uE Can't wait for the next one when he quadruples it.
                      I wonder if he actually believes his own bull shit? I would like to see the video where someone tied the cables around his neck and shoved the batteries up his ass, that should get some youtube time
                        /facepalm
                          I don't think this formula has any reasonable basis , but it could be a reversed trick used by those guys , as inspired from some true international standards , and then play on it and fantasize .
                          Here , i remember when we used to implement huge servers in a complex , a Hotel , or banks , a cable going from main server has an international length limit of 110 m precisely . After that , it's rejected . Of course , the formula here does apply and resistance is surely one expected parameter .
                          I remember also , that one time , i had to rise the Ethernet outlet 2.50 m on a wall , and let the cable inlet do the difference , to fall into the acceptable range .
                          But what i know for sure , when i was sharing Ethernet with friends , the stronger computer usually makes the difference , leaving others complaining and nagging ...
                            fsck google/youtube suggesting more of that idiot's videos... <clear cookies> aaah better.
                              nah.. .speed actually have many factors...
                              your cable modem... the cable use to connect, e.g. rg6 ... splitter, and misc
                              so either if cable modem too old / bad or cheap coaxial cable.... many issues... / so as cable taps / splitters.
                              here we have and use belden cables, as recommended by the cable installer ... splitters
                              provided by cable operator here is regal or APH (Singapore).
                              Good LAN cables, maybe can get AMP / Pandult / 3M, consider Cat 6 cabling for long run
                                If your ISP doesn't give you the bits of information fast enough, it doesn't matter what you use inside your house.
                                You could have the fastest best connection inside your home, but from the moment it goes in the ISP box (cable modem, DSL router etc) it's out of your hands.
                                Cat5e is more than the required quality level for 1 gbps speeds, using Cat6 or Cat6a cables won't give you lower pings or faster speeds, you'd still be limited by the INTERFACE (the network jack) the ISP offers you on the router/modem/whatever and then by the traffic shaping or limits they have installed inside that box or at the ISP level.
                                There's four pairs inside the network cable (for 1gbps, just 2 for 100mbps) , and you're dealing with AC voltages on each pair, batteries won't do shit for the signal going through those wires. Reducing resistance also doesn't do shit, all those types of videos are just to troll people or they claim ridiculous things for increased number of video views, which in turn makes the video owner money.
                                The resistance thing is bogus for other reasons as well. Normally, network cables are made out of strands of copper with a standardized resistance per meter. Network cards and equipment like switches and routers and modems are designed from the start to send signal through those 2-4 pairs of wires with such strength to achieve the standard 105 meters maximum length in the standard.
                                Because this 105 meters distance is very rarely reached and most people use network cables in offices or locations where distance between devices doesn't go over 20-30 meters, some clever guy thought of using aluminum strands plated with copper, because aluminum is cheaper... so the percentage of copper in network cable is much smaller, cable is cheaper, but the resistance of the cable is higher than the one in the standard. These cables are called CCA , Copper Cladded Aluminum.. and they work great for small distances.
                                However, recently other "clever guys" that make network equipment figured the same thing and said hey, let's "invent" power saving features, a green mode for the network card, where the card will gradually lower the transmission power as long as no transmission errors are detected, to save power and to add another marketing point on the network card's chip feature list.
                                In time, the quality of the network chips has improved quite a lot, the algorithms to detect signal, amplify and decode signal have improved a lot, so even with reduced power transmission at the other end, the chip receiving the data is smart enough and powerful enough to receive the data and auto correct whatever bits are hard to read due to low power transmission, so modern chips can work well even at distances as high as 105 meters with proper network cable.
                                However, when you have two chips talking to each other at low power (green mode active on both) and you also add a CCA cable that has added resistance, everything gets screwy at long distances (let's say if you use cables over 20-30 meters long). Disabling the power saving features from the network card's driver setting solves the problem.
                                So just use quality Cat5e network cable (doesn't have to be Cat6 or Cat6a, you only need these if you think you'll use 10gbps router/switch at some point in the future)
                                Another thing that's worth keeping in mind is congestion.. let's say the ISP gives internet through a 100 mbps network cable but let's say you're in an apartment building with 20 apartments. Well, those 20+ apartment cables go into a network switch somewhere in the building and that switch probably has only 1gbps port at the output - those 20 apartments share a 1gbps link to the ISP, so if all people would use their internet connection, each person would only get a maximum of 50 mbps because the output to the ISP literally can not do more than 1gbps in total.
                                Luckily, having 20 people use their internet connections to the max happens extremely rarely, almost never.
                                BUT, those fiber cables going from each apartment buildings are also going somewhere... for example you may have 6-8 apartment buildings each with a 1gbps fiber cable and these go somewhere to a sort of switch that converts those to a single 2.5gbps+ connection or maybe several 1gbps fiber pairs in a larger fiber cable...
                                Basically the idea is that between you and the ISP there can be multiple choke points, where there's potential in some situations to appear limitations unrelated to how good your home connection is.
                                  As I remember that method of hooking batterys to the internet is a method of talking to e.t.s or dead people. In any case the n.s.a.is listening.
                                    If you are running on WiFi then you might very well triple your Internet speed by connecting to your router by ethernet, instead. I don't know how the batteries and electrical tape are supposed to help.
                                    It is always safest to assume that someone is listening.
                                      With the e.t. ,ghost,big foot part, I was being funny,but not the n.s.a. part. It's like from the book 1984 big brother is watching.
                                        Will changing the router channel to the one that is not as frequently used by people in my locality help in increasing my internet speed with inSSIDer software to detect which channel is not as frequently used.
                                        Also will eSpeed Accelerator from Predator studios which is a registry edit file help in increasing my bandwidth to a minimum of 30%.
