Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Samsung UE40F6805SBXXE
    Back sticker:
    System board silk screen:
    System board sticker:
    Latest firmwares as of posting:
    IC901 I2C EEPROM
    IC1304 SPI Flash
    EDID
    The eMMC-dump from IC1301 compresses to 1 GByte, send a pm if you need it.
      LG 32MN58HM (EAX66684405(1.1) flash dump please.
        I have a Tesco (Technika I believe) LCD 22-229 that has a corrupted flash ic as cannot retune freeview and no languages available.
        Main board T.MSD306.65A 11503
        screen LTA216AT01
        Does anyone have a working dump for this model or similar? As I maybe able to edit the original dump to see where the issues are?
        The only one I could find was on the russsian site here (which I cannot register on!)
        Thanks in advance
          I have a TV TELEFUNKEN TE32269B38Y2D with VESTER 17MB211 and VES315WNDL-2D-N15 panel.
          The TV turns on, but the display shows some channels in contrast with double numbering (the one that appears after having done the channel search).
          It does not accept any command except the OK from the remote control and after giving so many OK the TV restarts with the same numbering problem!
          Practically there is the damaged software.
          I tried to load a new DUMP on MX25L1606E but the problem remains the same.
          Does anyone have a USB update?
          It may be that with that you get back to working properly.
            3820 ?
              Thanks it worked a treat I compared the original Faulty flash and the one linked. There were a couple bits of data that was corrupted so I used the one linked as I could see the majority of data was the same besides the tuning data.
              This can be used with the Tescos LCD22-229 Technika LCD22-229
              I appreciate your help
              Be Lucky
              Be aware don't use Menu 8888 to reset the TV as immediately afterwards that was what corrupted the flash ic in the TV!
                Originally posted by Daniman74 View Post
                3820 ?
                https://www.electronicforum.ro/viewt...17MB211#p23390
                  I uploaded this link file
                  But now I find this image !!!
                      Tray
                      https://files.fm/u/d25bvqqt
                        NADA
                          NADA
                            3820 is nothing to do with the board, the configuration, the screen details, the software etc.
                            The only relevant numbers from the board are the long numbers. One is the serial number of the board if I recall this is the first number that's 10113175 the second number is the board number with the relevant screen information and configuration details ie 23456606. This number 23456606 is the number to look for on the main board when looking for a replacement board for the TV! As the same TV model can have more than one screen fitted to it and unless you get the correct one then more than likely your screen output will be incorrect.
                            A lot of big sellers who sell these boards in bulk on ebay uk are clueless to this information and normally use the serial number as the board model number! Which if you think about it every serial number is different! So unless you do your homework then you will be floundering in confusion as to what board to order!
                            3820 ?
                              Nei 32NE4500SW
                              Mainboard: 17MB211
                              Psu: 17IPS62
                              Panel: VES315WNDB-2D-N13
                              Flash: MX25L1605D
                                Nei 32NE4500SW
                                Mainboard: 17MB211
                                Psu: 17IPS62
                                Flash: MX25L1605D
                                  SAMSUNG
                                  Model: LE40A558P3F
                                  Power Supply (PSU): BN44-00199A IP-211135A
                                  Panel: LTF400HA03
                                  MainBoard: BN41-00974B
                                    I have a Blaupunkt 39/210I-GB-5B-F3HBKU-EU that has a corrupted flash ic as it is stuck in standby.
                                    Main board TP.MSD309.BP85
                                    screen V390HK1-LS6-Rev.C8
                                    Thanks in advance
                                      hi, I'm looking for the firmware in bin format to be programmed or file to be loaded with key for TV kennex mod. TVC-DLE-385M8, main TP.SIS231.P83, thank you
                                        tp.msd309.bp85 flas dump
                                          Just checked when looking for a board myself and realised I made a mistake in my details!
                                          The first two numbers relate to the board when ordering. It is the third number is the serial number ie 27903359
