Compaq Evo 510 SFF stopped working
    Its not been a good week for me. First my 500gb external hardrive in a caddie stopped working ( this has all my work fies on) then on Thursday my pc booted up as nornmal allowed me to read a few emails then froze. It wouldn't reboot.
    It was running XP but with issues of it not being supported I installed Unbuntu 16.04 (32 bit) on the same drive earlier in the week and in the same partition. I suspected hardrive failure as I could hear loud clicking so changed the hardrive for a cloned one. This wouldn't boot either, screen said no boot media. I tried a second cloned hardrive but with the same results-. Can a virus do this? I wouldn't have thought so but just wondering!
    Bought an external caddie and tested all 3 hardrives on my laptop. The first one has definately failed (western Digital 200GB), now no clicking but no files either. The other 2 hardrives are showing all files. So if these won't boot either the desktop computer is at fault or the boot sectors have been corrupted.
    Anyone any ideas?
    Re: Compaq Evo 510 SFF stopped working
    Probably the boot sector on the HDD went bad as the HDD started to fail. Even though you've cloned it, it likely cloned the failed boot sector as well, hence the no boot.
    But best way to determine what is bad is to take another blank HDD and install XP on it (or whatever other OS you have on hand), then see if the system boots. If not, you do likely have a hardware issue with the PC somewhere. If it does boot, then it was the old HDD that had problem.
      I cloned the hardrives earlier in the week as I new I was going to install Unubutu. Xp program is saved on one of the working hardrives. I have no cd drive or dvd as these kept failing. I could try and make an XP boot stick, I tried for Unubutu but failed so i',m not very confident tbh.
        Somewhat related. When I had one of these, there were 3 obviously bad caps on the motherboard. While the PC worked with the 3 bad caps, I replaced them.
        --- begin sig file ---
        --- end sig file ---
          Hmmm. The CD/DVD drives failing and then the hard drive... that makes your computer hardware quite suspicious. As retiredcaps suggested, your machine may indeed have bad caps. Inspect the motherboard carefully. Also worthwhile having a look inside the power supply as well. Bad caps on either of these can cause all sorts of issues.
            Here is my post from 8 years ago.
            https://www.badcaps.net/forum/showthread.php?t=9582
