HP BIOS unlock tool
    Re: HP BIOS unlock tool
    Originally posted by ytsoc View Post
    you're right of course.
    Here's the dump
    Here, only flash this file
    Become a Badcaps supporter
    Thanks to all supporters.
      worked like a charm, thank you
        Hi there, I did buy two HP Elitedesk 800 G6 and now that I paid for them I learn that they are locked...
        I will receive the machines in about a week but I want to be ready.
        Is the tool in this sticky post work and if so can someone link me to it, the link to download it is dead!
        Or do I need a different tool for this model?
        Is the Ch341a programmer appropriate for this model?
          You can use RC unlocker tool : https://www.badcaps.net/forum/showthread.php?t=98539
          You can use Ch341a but it is a cheap and unreliable programmer, be careful with it, if not sure post your bios file here and don't act hastily.
            Thank you! Your tool worked on HP Probook 640 G1.
              Can someone help me delete password for my 8470p?
              I tried RC unlocker but not work for me. I tried it on Win7, Win10. Copy files to C end with permisson error and when I open it in folder RCUnlocker another error appears.
              I tried add permissions to .exe file, turn off UAC but error is still here.
              Tried rename file to dump.bin, not help. Install python from official page not help.
              I attached my dump.
              Thanks all for the answer.
              (on pic is second error when I open it in folder, not IN C.)
                Originally posted by denis182 View Post
                hi all,
                can someone help me delete password for my 8470p?
                I tried rc unlocker but not work for me. I tried it on win7, win10. Copy files to c end with permisson error and when i open it in folder rcunlocker another error appears.
                I tried add permissions to .exe file, turn off uac but error is still here.
                I attached my dump.
                (on pic is second error when i open it in folder, not in c.)
                  Thank you. It works, password removed
                      I attached my dump.
                      I am sure you did get the unlocked file, despite this error.
                        yes program created unlocked file, but I mean it dosen' work. I don't try it..
                        It's ok to use file created with this error? Thanks.
                        I attached this file.
                          You can use it.
                            I have been working on a GUI for unlocks - sofar lenovos are down to 2 clicks and HP is one click unlock
                            https://github.com/amjfrankenstein/BiosUnlocking
                            any help is appreciated i have built for raspberry pi (spi:0) and a dediprog SF100 that i use as well.
                            This is a first try for making a GUI so i'm sure it's sloppy
                              How to use it ?
                                Please help me i have the same problem HP endpoint security controller. Thank you
                                  Did you reset security settings to default?
                                    HI team , I have the same issue with the message :
                                    "there is a problem with the hp endpoint security controller "
                                    How could I fixe it please advice
                                      Did you read the previous 2 posts ? have you tried resetting default security settings
                                        Hi All, i'm getting this error message.. "HP Endpoint Security Controller Problem
                                        There is a problem with the HP Endpoint Security Controller on the unit
                                        Please contact HP Inc. to have the unit serviced ".. after trying to program HP 850 G6 bios chip.
                                        What i do wrong?
                                        Attached the U366 IS25LP128@WSON8 content.
                                        Help me pls!
                                        (Translated by Google.)
                                          What i do wrong?
                                          Help me pls!
                                          Were you able to enter the bios settings before the "HP Endpoint Security Controller Problem" message popped up?
