Can SSD Password be recovered from BIOS bin?
    Recently a friend of mine bought in a Panasonic toughbook CF-54 with a locked BIOS. I was able to unlock the BIOS with the help of good samaritans here. After unlocking I realized that there was an SSD password. Before unlocking the BIOS, when I switch on the laptop, it would boot into a custom windows 8 with preloaded software without asking for any ssd password. Now I did not know the password and as it was urgent, I bought him a new ssd and sent him his way home. Now I have the old ssd with the password. (Attached the picture). I inserted this SSD into an old dell laptop and it prompted me for the SSD password which I do not know. The ssd does not have PSID to do a PSID revert. I also tried the HDPARM method but it failed. I have the copy of the locked BIOS bin with me (Attached the bin). Is it possible to retrieve the password from the BIOS bin? Is there any other method to unlock the drive? I don't need the data. I just want to make the drive usable again.
    Re: Can SSD Password be recovered from BIOS bin?
    What errors do you get when you try to use the hdparm method?
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
      although a password could be in the UEFI partition, it's more likely to be in the TPM eeprom
        SG_IO: bad/missing sense data
        I followed this guide - https://grok.lsu.edu/article.aspx?articleid=16716
        I am attaching pictures for reference. I tried this on a laptop as well as on a PC. Same error in both. Tried power cycling but it didn't work.
          "enhancedp"
          try without the p
            "enhancedp"
            try without the p
            If you look at the next command, I corrected it. It still did not work.
              you still tried to pass the "p" as a password though
                I reproduced the steps in the following guides.
                https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
                https://www.ibm.com/docs/en/linux-on...ion-sata-drive
                I am still getting the same "SG_IO: bad or missing sense data" error
                However, I also tried your recommendation now. It says "Missing PASSWD"
                The HDPARM erase command requires a password it seems. That's why in all these guides there is a step to set the user password and then run the secure delete command using the user password. I am also attaching another image. Let me know if it helps.
                  You have something similar to mine, which needed quite an effort to achieve
                  https://www.badcaps.net/forum/showthread.php?t=105765
                  https://www.badcaps.net/forum/showthread.php?t=105808
                  Seeing your PM851 has no PSID on its label (a 32 character code I believe), PSID Revert isn't an option for you
                  Although there may be faint hope if PM851 is Opal compliant:
                  https://github.com/Drive-Trust-Allia...ki/PSID-Revert
                  Failing that, based on my experience, you may need to get back the CF54, put the PM851 back in it, then go through a process similar to that required to unlock the CF54 BIOS
                    @ajithpoison
                    In some laptop models there's an hdd master password in one of the DXE drivers, 32-hex pair password, that is used as a recovery to secure erase the hdd.
                      Unfortunately the drive is not OPAL compliant (refer attached picture). I did go through all your posts before posting this new thread. I have gotten in touch with my friend to see if he can hand over the toughbook for a few days so that I can try something with it. Will keep everyone posted once I get a hold on the laptop.
                        Originally posted by AAAC View Post
                        @ajithpoison
                        Is there a way to find it out? Probably a guide of sorts? When switching my PC on it asks for a user password. It also gives me an option to hit ESC and enter the master password. (I don't know either of these passwords)
